there you go boys, needs a bit of aesthetics, like wheels and a few more black bits but performance wise its pretty sick, has semi slicks on it and a high flow turbo, apparently 220kw but a dyno will tell me that next week once i can fiddle with the boost as its only 17psi on the high flow!
no one runs 18s on evos, ive looked around and talked to people and they all say the same thing, it creates to much unsprung tension.
its a sports car not a show car so i dont really care, plus tyres are heaps cheaper for 17s
Is that an aftermarket bonnet?
nope standard benji.
do they race theres yet? i still have to look into it as it may make 1/10th of f**k all difference, but i know smaller is better.
got a physics lesson off a wheel seller the other day who races his evo alot
You can pass on this lesson next time I see you then
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
