New member here,
My GT-R just went through compliance and they picked up on a few things,
Drivers side CV boot worn (no big deal)
Needs another brake light on the parcel shelf
Brakes are undersized (does this mean the rotors are worn? or the size of the rotor isnt up to spec)
Headlights need adjusting and also needs 3 new wiper blades....
They said its not that bad and that most of the money will be going to the actual certs.
They also said that the rear diff is a bit tight, is this a big problem or even something that is looked over in the compliance? or are they just trying to get more money out of me.. :3some:
https://www.sau.com.au/forums/topic/402609-compliance-failure/
The money you paid for compliance should be covering those things (cv boot, brake light, headlight adjustment, wiper blades etc) as far as I remember. Only tyres aren't covered in compliance (only if the jap tyres won't pass)
Car should be ready this week, is there any section on the forums where members cars can be displayed along with mods etc...?
Still not sure if I should grab 2x HKS 2860-5's or a t04z (single should be cheaper even with manifold) 044 pump, high capacity sump, N1 oil pump, ID850 injectors, and a Link G4 Storm along with other supporting mods. car is also on a jap tune, so that needs to get sorted asap
Any ideas where I should go from here?
Just an update on the car, I got the plates alright but when i took the car from the shop, it ran really badly, had to keep a revving it a small bit just to stop it from stalling. the car was misfiring pretty badly driving down the road at 2k rpm. but after a while it went away. I thought it was just the plugs fouling as this has happened with the previous owner. I gave the car a good run (50km's) but just before home the car started to slow and it stalled on the intersection as i was turning, would have gone off the road if i didnt start it in time! when idling I give the car a small rev and it drops down to nearly stalling then picks it up again...?
Should I get new plugs for it? the afms look alright, but I'm going to convert to MAP sensors soon so would it be worth my time? the tuning place is about 4 hours drive
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
