  • Replies 81
haha I like this bloke. He gets where I'm coming from. Great minds think alike hey Tai1or Made? Burn me bitches haha :thumbsup:
http://www.skylinesaustralia.com/forums/topic/402108-bodykits-in-perth/page__fromsearch__1
thread is pretty sweet, post pics when ur done with LED's, always wanted to do the same with my car, im useless with DIY electronics though.
how much would u charge to set up the same system u have in ur car under my 33 FE4R?
do want.
on topic, keep the B&W bishes coming!
hey maybe instead of spamming the same generic pics of floozies, you guys could stop posting crap and give the OP some constructive advice? Serious amounts of fail on this page.
OP: do what you want with your car, haters gonna hate. LEDs would look cool, I think the blue gives the best 'street racer' look personally, esp if you can thread some up through the front bar and intercooler.
Have you thought about getting some vinyl wrapping on the panels for that real tokyo drift look? it'd be awesome!
You have a profile pic of a young asian boy and a donkey....... and your saying theres a massive fail on the page...hmmmmmm.....
wasteland this already, its only going to get worse
What do you mean going to get worse?! This is the best thread out!? TROLOL. +1 Million points for the polka dot panties! haha.
@bozodos - it was bound to happen. Not to mention I LOVE floozies so it's all good ;) Also I don't really want blue. I've got a B/W theme going with my car anyway. Also I don't yet have an FMIC :( It's on the to get soon list though. Thanks for the input though instead of coming to a thread about something you don't like and posting something useless. Why bother coming to it at all? Like a sir!
Don't install a front mount, you'll have no room for the 18" deceptecon badge.
it's Wotaken brah, lern2japaneseculture
no probs OP, sometimes I feel that there is too much negativity on these forums and a real conservative streak instead of encouraging people to do something different
lol been to japan twice brah.....Im more than happy with my real knowledge of japanese culture vs japanese pop culture (and aussie trends of that).....
Also you talk of doing something different....what 5 terrible years of car culture and trends that followed the release of fast and the furious wasnt enough undercar leds for you lol....point is that its been done a gazillion times and it was horrible when it was happening...let alone again
Edited by sinistaGTR
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
