HI,
I have a Damaged R32 GTR that I am wrecking. I was going to fix it but I found a shell and transpalnted bits and pieces.
No motor, box or harness, most other parts are availible.
I am Located in Sydney, I can post items at buyers expence.
Plese let me know if you are after a part not listed i will take pics and post.
Fuel setup was on and up and runing for less than 3000ks befor I lost it and heres whats left:
Under car custom surg tank, Tank fits on drivers side under car near back seat. It has 3x -6 and 2x -8 weld on bungs, was bolted to floor via Nut serts.
Dash fittings: all earls swivel except for speed flow one way valve
-6 2x straight, 1x 45deg,
-8 2x straight, 3x 90deg, 1x 180deg, 1x coupler, 4x hose clamp ends, 1x adapter to fit 044, SpeedFlow one way valve fits 044 and has -8 end
Earls Auto-flex hose lenths are a min of of -6 1m 1.1m and -8 31cm, 32cm 48cm, 72cm 1.2m 1.3m
1x 044 pump
1x Golan -8 fuel filter http://www.golanprod...om/filters.html for info.
6x 660 Rochester Injectors.
Get it all for $800 lot.
I have a passenger rear passenger quater pannel that I got to fix the car $200.
Front seats $400/pair. Drivers seat has some cuts/rips on it.
2x AFM and Apexi air pods $120
Doors (just the door itself and window/motor mechanism) $200 each
Stock R32 GTR twin turbos with manifolds heat shields - were perfect when i pulled them off the car but have been sitting around so i would suggest rebuild. $150
Rear Diff $350
Front Windscreen $150
Rear windscreen $150
Quarter windows $50 each
Best to just ask what your looking for and make an offer.
I will add to the post tomorrow
https://www.sau.com.au/forums/topic/402696-wrecking-damaged-r32-gtr/
  • Replies 91
Hi,
Rear quater - to repair car, I can take pics of drivers one on car now if anyone wants.
Front Seats - drivers is a little bit hows it going.
Door cards $50 each please look at pics,
Under dash trim with fuse cover - has a little glue residue on left side $30
If any one is interestid in the canon it was from a R33 GTR nice sound $100.
Spiro
0414 509 399
HI,
Sorry guys I’m 4 months into a 6month licence suspension and I work all around Sydney so I’m living with public transport ill try my best to get back to everyone but pics will probably be on saturday unless I get home early.
Hi,
I am willing to seperate the fules setup. Injectors $250, 044 $150, Braided lines and fittings - over 5m off lines and 10+ ends for $300.
also here are some more bits.
HKS Boost gauge. $30
Bonnet Lip $60
Brake Master $80
Clutch Master $80
Center Din Gauges $60
Dash Cluster $120
Side mirrors $50 each
Side Kick pannels $20 each
Rear Wing $70
Stering wheel, No horn $40. for all the ppl who asked i just found it.
Door Seals with ALL clips, little rip where window rubs on outer side inner guide side good. $35 Each.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
