PM's sent
Floor carpet (the big one) $80 pics to come
Lightly damaged passenger GTR front guard $80
Also some pics of qtrs and a quick coulple of roof so you can see where i cut it. more on request.
  • Replies 91
Just received my parts from spirom and couldn't be happier. Very easy to communicate with and fast postage. Cheers man :D
A update on whats left
Fuel setup from page 1 $700
Doors $150
Stock R32 GTR twin turbos - no dump pipes - Price Drop - $80
Center Din Gauges $40
Boost Sender $25
Under dash trim with fuse cover - has a little glue residue on left side $20
Front sway bars with links, brackets - $30
Side mirrors - $45
Side Kick pannels - $15
Boot lock liner top bit hard plastic linner. - Price Drop - $10
Attesa 4wd reservoir - Price Drop - $25
Peddles - Price Drop - $10 each or all for $25
Power Stering canister - $10 - sensor lead cut/missing
ABS pump - Price Drop - $50
Drivers side 1/4 glass with rubber - Price Drop - $50
Passenger side 1/4 glass NO rubber - Price Drop - $30
Dash - Price Drop - $50
A Pillar garnish both sides - Price Drop - $45 - Drivers side has 3 holes from single guage pod. will suplly pod also.
Steering column plastic - Price Drop - $35
Boot rubber seal Perfect condition - Price Drop - $25
Door/window seals - $ 20 Each please look at pics
Blower/AC boxes - $20 each
Tail Lights - no covers - $60 each
Diff cradle complete $800
Accelerator cable - Price Drop - $20
Front Windscreen Moulds - both - Price Drop - $20
Petrol Flap and cap Price Drop - $15
Boot/Fuel leaver with plastic - Price Drop - $5
Rear windscreen wiper motor - $25
Internal roof lights Price Drop - $5 each
Foot rest - Price Drop - $5
Gear stick rubber boots and ring - Price Drop - $20
Aircon controller Price Drop - $40
Boot hinge spring system Price Drop - $20
Recirculation pipe Price Drop - $5
Std blow off valves $40
Intercooler pipe left and right ends Price Drop - $20 for both
Glove box $20
Intercooler Brackets top and bottom - note top ones not in pic - not sure what the other ones are Price Drop - $20
HIcas ECu $60
Stock amp $20
Rear windscreen demister controller box $15
Floor carpet (the big one) Price Drop - $50 pics to come
Thanks
Spiro
0414 509 399
Steve,
Yours has been shipped as I said when I messaged you on sat morning. I did remove it from the list but i have found another one yesturday, it must have from my new shell.
To clarify you the boost sender unit that is under the Center Din Gauges for $40 is the sender unit for the guages.
and i have a secondBoost Solenoid Boost Valve Sensor Price Drop $30
Please let me know if i can further help.
Spiro
0414 509 399
Got Turbos and stuff today, top seller and sir i applaud you on your tetras skills, opened crate/box to check on turbos and there is no way i could get the stuff back in haha thanks again :thumbsup:
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
