Ok, so I'm about to throw on some cam gears so I began step one - check base timing so when I put it all back together I can set it correctly. Hooked up the timing light and something doesn't look right... Looks like its at around 27deg? (Should be 20)
Is this likely? Car runs ok (except is running out of injector hence the current work ready for new injectors and a trip to the tuner)
Is it possible that the harmonic balancer could be indicating the wrong timing?
My power FC shows 20deg at idle and advances as I increase the revs; should the base timing there match the timing shown on the harmonic balancer?
The CAS appears to be in about the right spot, not even sure what the range of adjustment is, but it appears roughly in the middle...
Engine manual guide for those playing at home...
Any ideas? Do I need to put the dial caliper down the spark plug hole to double check TDC/timing?
Cheers!
https://www.sau.com.au/forums/topic/402700-rb26-base-timing-a-little-help/
The 20 degree figure you see is the ECU assuming the base timing is 20degrees, it has no way of knowing mechanically what the timing is set to.
If it's a cheap timing light you may actually be seeing double taking the reading from the wire loop, confirm with coil #1.
Cool, that's what I thought - mechanical/electronic base timing is independent.
I used the blue loop at the back of the engine; I'll have to test it again using coil #1 I guess. I figured if it was the wrong coil/signal it would be ~60 degrees out though meaning it would either be right or way wrong. Is this the wrong assumption?
Definately use coil 1, heaps more accurate reading, dont know if u csn lock the timing on a power fc, but if u can u should do that when setting ur timing
Locking the timing isnt really required, just be sure to match ur base timing with what ever the ecu is outputting at idle at the time of setting
+1 for high tension lead between plug and coilpack
nah just zip tie the mouth of the timing light open and hold it against the front of No1 coil, works fine, as Jez said the "timing loop" can show upto a 15deg change in actual timing
I know if I check the timing on my two GTRs before they are full temp they can read up to 27deg adv at idle, depending on how cold they are, so full op temp before you check it
having said that if the car was/has been tuned like it is then put it back how you found it and ask the tuner next time its tuned
^^ good advice. Just as a follow up, I did check it off no.1 coil and found no difference, but I'm in the process of fitting cam gears and new injectors so it will need a tune once done. Will put it back as it was and get the tuner to check it.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
