  • 4 weeks later...
Carbon bonnets in most cases can be cut and polished just like paint( except dry carbon)
megulars m105
Or farcula and a buffer
Then use some fireglaze in top of a show car glaze applied with buffer ( do not use lambswool pads!!!)
other choice sand up from 4000 to 12,000 grit then above , if the bonnet has cleared paint then sand carefully and repaint with diamond clear from DNA paint
It can be flow coated with a new product that looks like 25 mm of standing water its so shiny but the cost and process is a big one left for a carbon layer , the product has to be imported from USA not sold here but is UV stable and used on jet engines cowl so heat from the sun wont touch it , note real carbon sands real easy and you can buff right thru it in a flash so use care
Most bonnets sold here arent UV stable and get crappy in a few years if left untreated or in sun a lot
Paint it body color for the "its stock look"
Mine is a FRP though , and it has big arse Aerocatch locks on it so its not as stealthy as it once was, but at least now it wont fly up at speed.
Ever since i got a bad recommendation from autobarn and it ruined my cf bonnet, ive used the meguiars plastx cleaner and polish.
It still need to be redone every now and then but the car rarely leaves the shed when its raining so it stays good for a while.
Ive actually just looked at the bottle and its the lowest restoration fix of there products. there is a moderate and severe to try. So until i paint it to match car was going to try the moderate if i can find it.
But it works just like polish and ive never had a problem with it. And when i did use the stuff i was recommended from autobarn the bonnet just about matched the white paintwork so it does its job.
If its sprayed clear , treat it just like a car paint , wax it etc, just remember the clear will be much thinner ( some will be epoxy clear other lacquer which cracks and hazes fast)
You can also get what is called "blushing " kinda a wipe off hazy look thats from non UV stable and possibly chemical reaction still occuring in the epoxy from the heating, in that case let it cook in the sun one hot day then wash with good car soap not kit or some crap like dish soap
And show car glaze and your fav good paste wax
Once again not turtlewax, kit or cheap crap
Using only microfiber towels to wash and dry snd polish not lambs wool for anything or sponges
If you drop the rag grab another one dont use it again
And when you wash rags DO not use fabric softener it leaves a haze on your car and smears
The epoxy used on carbon bonnets is paperthin in most cases so sanding or even a detailer polisher can be dangerous and require a reflow of epoxy or even carbon repair which is paper thin too
Edited by Carbon 34
  • 5 weeks later...
depending on how bad it is take it to a mob called aquadip i have seen them fix up faded carbon bonnets just by cutting back the resin and reclearing it again i think it would be better because clear takes alot longer to fade and go that yellow colour than resin
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
