awesome thanks!
will have a go at this and see if i get it.
Also just on this, seeing the damage in pics, has anyone given a crack to repairing these lips?? Are they to brittle to try and fix etc?? Or are they meaty enough to handle fixing? And it will be sprayed the same colour as my car
Edited by Adz2332
ive never seen a series 3 lip in person... this is my current lip.. whats the differance??
Mine isnt a series 3 lip already is it???
I think it has series 3 headlights
PS the lip was banged up like this when i got it lol
Adam if that is your lip in those pics you already have series 3 lip :thumbsup:
Mines the black lip on the white car?? The 4 pics posted in a row.... Since asking the question I've had mixed responses lol, could be a series 3 lip, na doesn't look big enough etc etc!
Is there any serial numbers or anything on it I can look at?
S3 lip as everyone has said.
Definitely NOT S3 headlights, clearly not a Xenon.
And the first lip pictured wouldn't wanna be anymore than about $3250given how much work will be needed to clean it up and fix it.
Decent 2nd hand S3 lips go for around $600 - i picked one up late last year in the FS section at that price
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
