hi guys as you can tell i'm new to the forum here, and i just bought myself a v35 350gt-8
i apologize if these questions has been asked before i've done some research and looked through the forum and coulden't find anything :S
anyway like i said i just got myself a 350gt-8 and its my first car
i've always liked cars but never really got into the mechanical side of it and my question is i need to do a major service on it soon and was just wondering is the cvt, transmission and gearbox all the same thing? if so do i just need to service the cvt and then the transmission and gearbox would be done as well? or is it all different parts of the car and i gotta service it all individually?
also where can i buy the cvt oil for the 350gt-8 and how much would it be? as well as a tutorial on how to do this?
also when i bought the car the guy said that the display screen has a loose ground wire so it doesn't work :S where is the ground wire located on the display screen so i can fix that? and is there a tutorial or something where i can do the ipod dock mod? or possibly instead of an ipod dock an android dock mod? seeing as i have an android phone
and the last question is what bulb type does the v35 use? i know the low beam is a hid d2r and the parker lights are t10, but what about the fog lights and high beam lights? i want to change the fog and high beam lights to white bulbs seeing as the low beam has a white bulb
again i'm sorry if these questions has been asked but i'm new to the forum and owning a car lol :S
i know this must have been a long read but any help would be much appreciated
https://www.sau.com.au/forums/topic/402925-quick-question/
How deep are your pockets? Because that gearbox isn't exactly known for being reliable. The oil for the gearbox is not cheap by all means that's when and if you find it, it's usually on Ebay.
As for the globes I can not remember from doing mine.
Good luck with the CVT mate, if you treat it right it should be fine.
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6406998
so the cvt, transmission and gearbox is all the same thing? meaning i service 1 then i service all? lol my pockets are deep enough i guess but how deep are we talking about for the oil? and what type of oil is it or the name of it? :S
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6407027
The CVT gearbox is about $1k and genuine Nissan oil from Nissan is the only way to go. DO NOT service the CVT yourself, unless you are extremely mechanically competent, but sadly there ar eonly a handful of workshops in Australia with any idea about the CVT gearbox at all.
Sadly I think the guy was pulling your leg about a loose ground wire - and if it was that easy to fix, why didn't he fix it before he sold you the car?
The high beam/fog lamp is a H4 dual filament. You will never find a high beam light anywhere near the whiteness or intensity of your low beams, as the low beams are HID. The closest you will find is the Phillips X-Treme Vision, but even they are yellow in comparison to your HIDs.
http://www.ebay.com.au/itm/1-x-PAIR-Philips-H4-Headlight-Globes-X-treme-Vision-100-Brightest-Upgrade-EVER-/140747389599?pt=AU_Car_Parts_Accessories&hash=item20c532ba9f
Your bible of all things V35 sedan is here:
http://g35driver.com/forums/g35-sedan-v35-2003-06-15/
Every single thing in the world you could ever think of has been covered in the G35 forums!
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6407039
Gearbox and transmission are different terms for the same thing. A CVT is a type of transmission, just like a Manual and standard auto are types of transmissions. the only additional item you need to be aware of on a RWD car is the differential, which is at the rear, it also has oil that needs to be changed at specific intervals.
I don't think the CVT is all that bad, there are a couple of horror stories, new fluid is insanely expensive and nissan are the only people who make it. The biggest issue is finding a mechanic who has a clue about them.
Here is an ebay link for the fluid.. not sure how many tins you will need for a full flush, probably 3 at a guess. That said, there was a guy selling 1 tin on ebay for about $350 recently..
http://www.ebay.com.au/itm/Nissan-Skyline-V35-350-GT-8-Transmission-oil-KTF-OIL-/220879380863?pt=AU_Car_Parts_Accessories&hash=item336d6fe17f
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6407467
That link to G35 driver about the sedans came in quite handy man, that site is a pain to navigate. Thanks nightcrawler..
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6408311
I did a CVT 'Box in a V35 yesterday.
They aren't amazingly hard, just if you put too much in the sensor has a fit.
Little light on the dash came on - haha.
Just sucked the excess out with a pressure sucker.
The reason the oil is so expensive (someone correct me if I'm wrong) is the meshing of the CVT gears, not like a standard Trannie, and if you put the wrong oil in you can either ruin your gears by them getting gunked up, or by not being lubricated enough and shredding themselves. That's why you buy the Genuine stuff.
We got it $750 on trade, and we waited almost 2 weeks for it.
Any competent highly regarded Mechanic could do it if you want someone to be sure of (like.. a custom car mechanic, or well reputed workshop.)
But anyone can do it - just be careful, and follow basic logic and you can't really go wrong.
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6408405
A cvt doesn't have 'gears'. The cvt in the skyline uses two pairs of toroidial rollers. A search on 'extroid' should yield some sites with pictures and a good description. There are very specific friction requirements for these rollers and the Nissan fluid is designed specifically for the extroid cvt. the xtronic cvt in other Nissan vehicles is a very different beast and uses a segmented steel belt. It also has its own specially designed oil. Using a standard auto transmission fluid will destroy a cvt.
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6408772
thanks for the help but is there any mechanic in melborune that knows about v35 and how to do the cvt service?
GIve Nuwan a call. He will be able to help you with the CVT sevice. He is located in Bayswater.
He is very familiar with V35s and he services my 2006 V35 coupe as well.
His number is 0422807393.
Cheers,
Keith
p.s. If you can make it, pop over to the Garage Cafe in Carlton next Friday 29 June to meet some other V35 owners in Melbourne. (See separate thread).
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6409171
Cheers,
Keith
ok thanks for the guys number i'll give him a call when his free any clue to how much he would charge for the cvt service?
about the meet up can you link me to the trend i might drop by
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6409255
I think FrakMunkie makes a good point too. A normal service on the CVT shouldn't need any special knowledge other than the required fluid type and how to refill to the correct level. A normal auto transmissions service just involves a fluid change and a test drive.
When you need faults repaired you need someone who really knows these transmissions..!
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6409348
Is there a filter or mesh to clean and/or replace in these?
That is usually part of an auto tranny service.
https://www.sau.com.au/forums/topic/402925-quick-question/#findComment-6409428
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
