thought id do a big bump on this one.. I am still getting the blip of power to the front wheels (shows up on the front torque gauge) now and then usually when the gearbox shifts from first to second gear.. no 4WD light ever. (thanks scotty - that was just a faulty relay). Though this blip of power to the front wheels even when using very low throttle causes the car to do a very ugly shift into second. or very occasionally a slight surge at 60-70kmh.
If i pull the relay and have the 4WD light come on (hence RWD only) car is smooth as silk.
also smooth as silk if i flick to synchro.
Anyone else have this problem? Going to bleed the atessa with scotty in the next couple of weeks though would like to see if anyone else has any ideas.
just been doing some googling. Some people are saying that it can be caused by non-matching front and rear tires.. I run factory ARX 18's they did come with 235/50/18 though i changed them to 245/45/18. surely it cant be that??
Cheers.
Edited by Sage222
If all the tyres are matching there isn't much else you can do, unless the fronts are worn more than the rears?
Hopefully it just needs a flush, new fluid can only help it, and get rid of any built up air in the system.
Today I had my first encounter with exactly the same thing between 5-10% torque showing on the gauge in 1st gear and into the beginning of 2nd... No green 4WD light up on dash either.
Made the car sound like it was working extremely hard but performance was anything but. Didn't at all turn the tyres was probably best described as like a slipping manual clutch sensation...
Ok it had been very lightly drizzling in Adelaide, still I had pictured qtr turn of opposite lock to be the result...?
Only owned NM35 for a couple months...
So is this the normal occurrence
  • 3 weeks later...
just an update for those following and or having the same problem. My car was due for a front right wheel bearing.. This seems to have been causing issues with the atessa. making the car pulse power to the front wheels when cruising (50-80kmh). Also even gave me a symptom like fuel cut when using near or wide open throttle. both these things have been fixed by the wheel bearing replacement.. (thanks Scotty!).
quite strange. we bled the atessa fluid too. so now i am back tot he occasional blip of front torque when going from first to second.. no other symptoms..
  • 3 weeks later...
yeah mate. running real well i reckon that atessa bleed has helped too.. just need to do that dif bush let me know when you get em in :)
I sent diff bushes down to Scotty last week, if Auspost get off their arses they should have them to him shortly.
you may be interested - in cold Russia the most suspicious part of ATTESSA is used to be the pressure control switch, which causes C1208 error reading
this is one of this crap pieces
it's not aviable to order from Nissan separately
we have found the replacement one -
http://wako-clinac.co.jp/product_en/ps-20_en/index.html
the thread is metric M10*1.25
length of thread 10mm (2.5mm O-ring)
  • Like 2
Nice one Erop, I have an assembly here with pressure switch problems, I might give this switch a shot. Thanks.
You don't happen to have a part number for the correct pressure and thread do you?
this switch is only marked with PS-20
the WAKO doesn't sell less than 1000 pcs :angry::angry:
now looking for byuing this switch, still no exact code, Scott's right
BUT - you may take it from R32-R34, Laurels, Glorias - their ATTESSA is similar in such parts, and their used spares are cheaper
in my mind - the reason is lack of changing of this fluid, which causes mechanical problems in winter, cause my one (350K on odo since 2001) still works, i replace the ET-S fluid every year
Edited by Erop
  • Like 1
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
