Hello all, unfortunately i think i'm going to have to sell my RB26 and all the associated parts i have bought for it so far. I've gone a bit overboard with my RB25 which leaves me struggling to finish the rest of my car. All the other parts are up for sale.
I'm in Adelaide.
Photos for the RB26 and parts can be organised if you need them.
This is just an EOI for the RB26 and parts to suit.
What i've got;
RB26 complete minus coil packs and injectors. Hot side completely removed but included. Cast mounting point for the alternator was broken off the block when the vehicle was in an accident, could possibly be welded back on. Wiring loom has been stripped of all un-necessary wiring (1/2 complete), ECU, 1x good AFM, 1x damaged, Harmonic Balancer damaged. engine is otherwise complete. Looking at $1800
R33 RB26 Block and crank very good condition - Was to replace the damaged block - $600
CP 86.5mm RB26 pistons new in the box - $800 Firm - Cheapest you can get them for is $900
RB25/RB26 Carrillo Pro H Beam Connecting Rods with CARR Bolts - One of the best rods on the market! - $1400 (These cost me $1600 a year ago). These rods are for the serious builder.
Full Genuine Nissan RB26 Gasket Set - $250
Brand New Tomei Inlet Adjustable Timing Gear - $200
ARP RB26 head studs new in box - $300
WIll do a deal for multiple items bought at once or the whole lot.
Brand new in the box Greddy Profec B Spec II - Going with closed loop boost control with my new ECU so this is not required - $320 including express delivery to you.
R34 RB25 NEO ECU (Auto) and Nistune. The Nistune board is NOT installed into the ECU yet. - $400
RB25NEO Harmonic Balancer. Brand New Genuine Nissan item. I bought this from KMS several weeks ago, but i have now gotten ROSS to make me up a custom NEO harmonic balancer. This is no longer required. Brand new, suits all cars with the NEO engine. $320
RB25DET NEO pistons and rods - 39,000km on them. Very good condition. I'm forging my engine so these are not required. $200
RB25DET Neo engine cover - very good condition, no broken plastic, comes with all the mounting brackets - $100
NEO intake pipe, recirculation pipe and cross over pipe - $100 ono
PM sent
SMS Sent
Would you sell block with girdle only (minus crank)?
Sorry mate, crank stays with the block and girdle. Tried to PM you but your inbox must be full.
I have personally looked over it and found no issues at all. Im quite anal about engine parts and the block and crank are in great condition. If it wasnt i wouldnt have bought it.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
