I'd be getting rid of the dumps, cause I had the same dumps and the same issue. Since changed over to Midori dumps (but changed to -5s as well)
Oh I see....well that's the thing - I've been reading about peeps who swear by them and then others who're fans of the bell mouth style ones which are what you're using (I think).
So did you have a set of -9's before you went to the -5's? Keen to hear more about these xforce dumps and why they're not that good...I'd be happy to swap them over or even put my stock R33 GTR ones back on (I know people make decent figures on these too and also use them as upgrades on the R32's)
I use xforce split dumps - they're fine. 305kw @ 17psi on -7s. 16psi at 4000rpm. If anything you could go slightly backwards spool wise with a bellmouth as they produce more turbulence post turbine. Changing dumps is turbo out, so not only will it not help, it will be expensive for labour....
Ah ok - that's the divided opinions right there haha
Ah the swap isn't too bad - I've gotten it down to about 1 day's solid work now but don't really want to do it again! Those are some nice figures by the way - you must have an excellent tune! Yeh at this stage I'm just going to drop the cat and cat-back out to see if there's any difference. If there is, it's new cat and new tune time ;-)
I have -9s with HPI bellmouth dumps one of the biggest on sale. Running 330awkw 18psi full boost 3800rpm.
I don't think your dumps are the main issue, yes could improve with different ones, but as stated before drop the cat and check/replace it.
I had an issue with a previous "hi flow" cat that was causing a 10+psi restriction
Wow those are even more awesome figures! Ok, well tomorrow I'll drop the exhaust and see what she's like and post it up on here. Yeh 10psi+ seems like a massive restriction - I'd probably have something like this too.
But yes, we shall find out tomorrow.
Thanks for all your replies so far - most helpful in a time of great frustration!
i have 18psi by 3800rpm on hks dumps so problems for you there, also had an issue with blocked cat previously and car lost 40kw, check for leaks as well
I'm assuming you mean "no" problems there...are you referring to the split dumps? 40kw hey? Yeh I need to gain at least that much....really hoping to make close to 300kw to make all the money spent worth while!
Also guessing you already know but don't flog the shit out of it with the cat dropped.
It's not going to be tuned for the extra flow and power so might lean out at some points
Haha offcourse not. I've been talking to the tuner about this...about how much margin there would be for this. I basically plan on just giving it a gentle tap because I'll know right away if it's had an effect - that's how poor it's performance is right now. Then I'll be booking it in with the local exhaust mob to get a proper hi flowing cat put in place, along with a larger internal dia canon
Yeh tuner didn't know much about my turbos...didn't even know -9's existed in the 2860 range :P Mainly does bigger turbos and singles.
She's obviously gonna need a re-tune once exhaust has been rectified (provided that's the only problem and it's not something more sinister etc etc)
just curious, if the tuner dropped the exhaust on the dyno how would the gases get collected, from what i seen the fans or whatever that suck them up and deal with them are right at the back of the dyno room, so wouldnt that fill the room up with fumes???
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
