Can all the Nissan followers please advise me the difference between GTR and V-Spec/ N1 is as far as components. (for R32 and or R33)
The main question is do I have to by a V Spec or can it be replicated...
Thanks Guys
TT
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/
Tom , contact Warwick Freemantle.
He has the R32GTR N1 spec that is approved for Targa .
Some of the mods are enlargened sump ( use trust extension)
17x8 wheels
Oil cooler
Aircon delete
Nismo style 580 or 581 type turbo's
plus other stuff I can't remember.
PM me if you want further details
Cheers
Ken
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-827841
Thanks Ken,
Sorry to see the boys parked on Arrowsmith. Talking with Doug over a bottle of champers at midnight and he seems keen to finish the business.
No Tony, I dont care if they are genuine or not... I'm just trying to work out the most cost effective way to get one! After passing quite a few 4wds in the last couple of years, I am beginning to wonder If I will be slower in the bigger heavier car - or the added grip off the turns will give me a 1/2 second / kilometer...
Only one way to find out.
TT
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-828307
Yes, n1 has different pistons and block as well.
It would be great to post up the R32 n1 specs if possible, there are a few on here that it would help.
TT, I'm building my r32 gtr to n1 spec piece at a time for production touring car racing.
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-828705
N1 has a better block. Ribbed for your pleasure.
N1 pistons are different but it's all a much in a muchness since they are all cast.
I would say that your could get yourself an N1 block and fill it full of Arias forged, Carillo rods, Tomei crank, composite gasket, Nismo 581 turbines, FC management and how da fark would they know???
Or am I taking an unfair advantage?
T.
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-829934
All the go fast bits, not needed for TT. Just reliablility & a good handling/brakes package. Things that help like exhaust size are covered in the rules and easy policed. Brakes, Wheel Size, and Added oil reserve + cooler however are the things I will include. Looking for about 7.5+rwkw/kg and that will do me!
And yes Duncan, a spec sheet would be great to sort thr sh1t from the clay.
TT
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-830832
Actually we have decided to stick with stock engine atm anyway, given everything else like injectors is stock we aren't exactly stressing it out with high revs....
Thanks for that link Robocop, that clarifies where the 245 tyres come from, and that v spec/n1 did not have cross-drilled rotors if I read it correctly.
Still lots of other things it would be great to clarify if anyone has further info :)
Unfortunately CAMS are unable to provide a set of N1 homologation papers, the only thing ever homologated here was the Group A GTR which is not really relevent. Its a bit of a hot topic in NSW combined touring car racing since (suprisingly) the commodores and falcons are having their arses firmly kicked :D
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-831125
TT
NO!... stick with the GTST, could not honetly say if its a case of pushing sh1t up hill using a 2L, 1250kg, RWD car for motorsport...but i need to believe the GTST can get the job done :Oops:
I love GTRs, but i have only been in one car that made me think they are the way to go (TrustGTRs car)... but i think 300kgs weight difference is a big step backward before beign able to go forwards...then again i have driven an R33 GTST with a 2530 and i think it would have have the measure of a lot of GTRs on a circuit, but circuits a fair bit different to a tarmac rally event i suppose
How did the older GTRs do in the Targa, in their class did they finish well? Was speaking to a guy that ran a GT3 this year, he said the copnditions this year made it very hard for RWD cars, something like only 7 of the 18 GT3s entered finished, and 5 were written off (number sound about right do they?)
Considering i was reading an article on the release and subsequent comparison of the R33 GTR and VR GTSR Commodore, on on the tight twist, hilly roads, the GTSR was showing a clean pair of heels to the R33 because of the punch out of corners, and quick blats in gear. As soon as the orads became a little more flowing and high speed the GTR demolished the GTSR... dont know how reliable/independant the Australian journalsist were that wrote the article... ramble, ram,ble, ramble, i make no more sense behind a keyboard then i do in person :Oops:
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-831769
Isn't the main reason every GTR in a road-event is an 'N1' so they can run steel-blade turbos?
Gary (R32Impul) has a genuine R32 GTR N1 fi you want to ask him specifics.
There was an HPI article about it a while back too - but it was for the R33.
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-831888
And I reckon Skyd would shreik in horror hearing I was considering jumping on the band wagon...
After Targa there is a huge let down, specially if you crash or DNF. In our case we put together a really good package, and I parked it against the bank.
Fact is I was having a red hot go because I was trying to be in the top 10 come end of day one... Car 814 (A Subaru AWD) was 28 seconds slower than me on Devonport (15ks We did 8:05) That same 4wd took 36 seconds off us in the Arrowsmith (47ks) in Wet slippery conditions.
The leading R32 was th Donut King entry of Alford and Best 13th o'all...
The advantage of the 4WD (any brand) is off the slow turns, where they can employ the point and shoot approach, our little girl is all about corner speed and we just cant get to the next turn as quick as them...
Anyhow we will try to sell and if not gone before August... we will saddle up again in 05. (My self mutilation is coming to an end) Maybe with an even better package.
The N1 specs allow 17" tyres, hence bigger brakes and a couple of other TT prerquisits. Steel turbines would be nice but not the be-all...
For you Roy...TT04d1flame_small.jpg - HERE!!
https://www.sau.com.au/forums/topic/40330-n1-whats-it-got/#findComment-832066
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
