Nevastator Posted June 26, 2012 Share Posted June 26, 2012 Hi all, Once again i've come to you in need of some help. My car ('93 R33 gtst) has recently started playing up, in the last month or so what's been happening is under load, full boost and high rpm, the engine light has been flashing. I've done alot of reading up on this and found that it is serious and requires attention. So this is me attending to it The mods on my car are as follows, Power FC Splitfire Blue jackets Boost T Currently running 12psi Highflowed turbo (OP6-hypergear ~480hp?) Greddy Front mount Bosch 040 Custom 3" straight pipe all the way through Standard injectors Standard afm What happens is when the car is warm (water temp ~82-84c) and I open throttle in either 1st or 3rd, from about 5000rpm the engine light will give me about 4 or 5 consecutive flashes. On the pfc display I get a peak knock reading of anywhere between 85 and 130. I don't have a wideband so i dont know what my afr is but I'm quite certain its leaning out badly. The guy i bought the car from said that it was tuned to 15psi (which i now think is bullshite) so running it at 12 psi shouldn't be causing it to knock so much. I'm in the process of getting a z32 and nismo 740's What i need to know is should I go ahead and keep driving it? Should I get it retuned? Should I wait until i have the afm and injectors then get it tuned? Just some advice would be nice as a mate of mine just blew his engine which had similar issues previously. Sorry for the long post... Any help is much appreciated Cheers Nev Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/ Share on other sites More sharing options...
AngryRB Posted June 26, 2012 Share Posted June 26, 2012 keep driving it with those knock levels and you'll find yourself walking home.. i was told anything over 60 is getting dangerous... so dont drive it that hard til you have tune, your probably running out of fuel with the hypergear turbo. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417019 Share on other sites More sharing options...
Kenna802 Posted June 26, 2012 Share Posted June 26, 2012 Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417048 Share on other sites More sharing options...
Kenna802 Posted June 26, 2012 Share Posted June 26, 2012 Sorry couldnt resist . What fuel have you been using Octane etc... Maybe you have an issue with something thats failing....Fuel Pump maybe i would be getting it checked out ASAP !!!! Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417065 Share on other sites More sharing options...
Manuel Kasko Posted June 26, 2012 Share Posted June 26, 2012 Neville you forgot something bro...Your memory ball. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417075 Share on other sites More sharing options...
Tai1or Made Posted June 26, 2012 Share Posted June 26, 2012 Ping away. Ping away brah. OT. Do not drive it in boost. Just don't. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417102 Share on other sites More sharing options...
vorse Posted June 26, 2012 Share Posted June 26, 2012 (edited) man do a burnout bounce it of the limiter burnouts fix everything on a seriouse note pinging bad do not drive it Edited June 26, 2012 by vorse Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417107 Share on other sites More sharing options...
Tai1or Made Posted June 26, 2012 Share Posted June 26, 2012 Neville you forgot something bro...Your memory ball. This thread is useless with Hermione pics. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417109 Share on other sites More sharing options...
Nevastator Posted June 26, 2012 Author Share Posted June 26, 2012 Always run on BP98. Will just a check from a mechanic do or should I go to a tuner? Just for when I do have it tuned, anyone know a good Perth tuner that knows what they're doing? Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417116 Share on other sites More sharing options...
Tai1or Made Posted June 26, 2012 Share Posted June 26, 2012 Get it tuned. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417153 Share on other sites More sharing options...
bozodos Posted June 26, 2012 Share Posted June 26, 2012 tried some octane booster? Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417207 Share on other sites More sharing options...
Manuel Kasko Posted June 26, 2012 Share Posted June 26, 2012 Get it tuned. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6417865 Share on other sites More sharing options...
DVS JEZ Posted June 26, 2012 Share Posted June 26, 2012 Try lowering the ign trim 3 degree's atleast everytime u go for a drive until u can get it tuned. You do this on the handcontroller Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6418018 Share on other sites More sharing options...
Nevastator Posted June 28, 2012 Author Share Posted June 28, 2012 Thanks for the replies guys, even the not so helpful ones... I'm getting it tuned in a couple weeks Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6420656 Share on other sites More sharing options...
TTT Posted June 28, 2012 Share Posted June 28, 2012 Speak to user lilcrash Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6420757 Share on other sites More sharing options...
Rolls Posted June 28, 2012 Share Posted June 28, 2012 Do NOT drive it on boost at all, not even 3k on boost, you will destroy the motor if it is pinging. Do what JEZ said, remove 3 degrees from >3k and it should be safe until you get it tuned. Link to comment https://www.sau.com.au/forums/topic/403465-should-i-get-my-r33-tuned/#findComment-6420973 Share on other sites More sharing options...
