As topic states a full set of 4 rims with tires
- No gutter marks
- Tire's are in excellent condition apart from 1 that rubbed on the guard
- 70 - 90% tread all round
- 5 x 114.3 PCD
- Offset +12
Looking for $1200 take them away
Located Central Coast NSW
  • 3 weeks later...
  • 3 weeks later...
