Hi Everyone
Impulse buy.... lol
This phone is pretty much BRAND NEW. I bought it to try it out, but no longer need it. I have never made a call on this phone, simply opened it, applied a $10 extreme branded screen protector perfectly with no bubbles or marks the second I took the cover off, and then tried out a heap of the features. It is a beautiful phone. As you can see on the receipt and box I paid $777 for it. Its time for you to grab a bargain at my loss :(
Its only 7 days old! It works 100%, and does not have a single mark on it.
All accessories are still in the box, new and untouched. It is 100% unlocked too.
It will have full warranty with JB-HI FI, and I will be including the reciept for you to use should you ever need the warranty.
Res: 640
Instant: 700
I'm in Mackay, QLD
Anyone that goes instant I will pay for Registered, insured postage.
I will also only post it registered insured.
Pics:
https://www.sau.com.au/forums/topic/403664-samsung-galaxy-s3/
Can I ask you why you bothered buying it in the first place and why you now have no need for it?
Not being rude, I'm just looking at going from an iPhone 4 to one of these but I'm still uncertain about it. Were you not happy with it or did you find something better?
Any info would be appreciated.
Thanks.
It had everything I needed. Very fast, awesome everything by two things.
1. Size - I like a smaller phone. It's much wider than the iPhone. It is lighter though.
2. Multiple mail accounts. It doesn't handle more than one mail account as well as the iPhone.
Everything else it has poos all over the iPhone.
So it won't do more than one mail account at all or does it just have trouble getting pushed emails?
Thanks.
This is the best android phone you can get atm and will shit all over your iphone 4.
Push is fine.
You need a separate mail program for each mail account.
Whaaa? You sure that's correct. I've got an HTC Velocity running ICS and the native email program handles multiple email accounts just fine. I have four currently pushing to it. I'd be very surprised if the S3 was much different. My best mate has an S2 and it does multiple accounts fine as well.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
