sup dudes an dudettes, i just baught my first ever r31 and its my first car. its the executive model and its stock as a rock. i dont realy like the front an back bumper on it ( black hard plastic) and was wonder hpw much the front an back bumpers are off a siloette or a s3 or something like that and maybe even side skirts. id also like to no the genreal price of lowering it 2 inches and a 2.5 inch exaust with extractors put into it. an maybe even a new paint job ( just simple gloss white) any help would me much appreciated
cheers
phoone
https://www.sau.com.au/forums/topic/403669-r31-help-needed/
the front buper has a little chunk taken out of it so i would like to change them anyways, how good does the racing sili front look!!! http://wiki.r31skylineclub.com/index.php?title=Image:Racingsilfront2.jpg
thanks guys this is exacly what i needed!!!
and as for the exuast any brand or extractors u guys recomend? im not a car wiz but ive always lved the r31,s one of my fav cars an i want mine to be a weapon. so i want it to growl hectic and look like a demon
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6423540
Go for handling, and for f**k's sake; do something with the brakes! They're woeful.
Re bush the whole damn thing if you can; you won't regret it.
Have fun, they're a great workhorse.
Mine did over 500,000km on it's original engine; and was still going strong when I sold it. Never used a drop of oil, or let me down once in 10 years of ownership.
Edited by Daleo
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6424007
especially the ferkn handbrake! brakes are same size as a pintara with a CA20E with naff all power
Edited by StevenCJR31
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6424011
yeah i noticed the breaks are shit house and the hand break is total dog shit, im gunna do pritty much everything to it like new suspension,breaks, be build the engine an all that jazz with a few extras also
would u recomend a quick shift in a r31?
id also lie to turbo my rb30e also, but what im readying up they nee some drastic changes like a diffrent head an cam shaft an all that shit, ive been reading up about it a fair bit an every site is diffrent and im not machenically minded im a simple carpenter so its all a bunch of numbers an shit to me lol.
i just want to no what the hell do i have to change for me to turbo it, not like 500hp change just like a garret t27 or 25 or something to that extant
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6424242
if the engine/trans/rear axle is in good condition to begin with then it wont go bang, if not then fix/overhaul first and it will be fine, heaps of info on how to wire in vl ecu on R31 skyline club forums
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6424266
yes its not too bad at all, i picked up a nistuned R31 computer/turbo injectors / turbo n oil and water lines/exhaust manifold / dump pipe/cross over pipe real cheap, the gent wanted $650 for the lot but i got it for $350 but as the turbo had a lot shaft play and needs a recon
https://www.sau.com.au/forums/topic/403669-r31-help-needed/#findComment-6424573
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
