Nice to know im not alone.
I was under the impression that Odyssey was one of the best batteries you could get?
It cost me a fortune.
Mine failed after a year with dead cell
If its not a grey import it should have a warranty ??grey market no warranty at all
a stuck relay can draw power
easy to put a meter on it and yank the fuses watching it for current draw
If you dont do a long drive weekly it will die ? buy a trickle charger designed for agm cell batteries
Or any battery will be dead , on GTR your current has to travel to the front and 925 is enough with big wiring , factory not so much
My agm battery with long drive weekly at speed , stereo etc off it becomes a bit sluggish if its cold out but still cranks decent , hot its is still strong for weeks even with massive draw of mutiple layers of security
Edited by Carbon 34
Thats your opinion and i gave mine.
And just to clarify, yes i should have said that 33/34gtr its perfectly legal for wet cell in the boot, however as for other cars/skylines that have had a conversion done, it is not.
Wet cells are not legal unless vented outside the car , hydrogen gas is explosive the relay boxes a few mm away can spark , boom flash fire with acid spray , overcharge a wet cell , acid bath in the boot nice!!
always mount your battery with a layer of bulk rubber mat under it , vibrations kill batteries and skylines are rough riding on oz roads , clark rubber , 4 mm thick or so cost f all
  • 1 month later...
I thought i would bump this thread,
my car has chewed through 2 battery's in the past 12 months.
The first one was a wet cell battery (car came with it) which died due to me not driving for 4 weeks when i first got the car, i put it on charge with a trickle charger, came back to it and there was acid in the boot, not to bad because i caught it just in time, but could have been everywhere. Have neutralized the acid, and prevented further rust, but i have to respray/clean up the boot and behind the rear passenger seats. Just light spotting where the acid dripped.
And it has done it just before Christmas now, how convenient, usually it takes about 2/3 weeks before it goes low and i will usually drive the car before that happens, all it took was 1 week to go flat, so either my alternator is not working 100% or there is another cause?
The new battery will be a Optima.
While i have my boot completely emptied to respray during Christmas holidays, is there any electrical work i should be doing?
I will be putting a new Nismo fuel pump in too, will the standard wiring be up to the job?
Edited by Grimesy
Look for the fuel pump direct feed rewire thread, it gets rid of the fuel pump speed controller and shows you how to upgrade your wiring to suit the pump and give it the juice it needs. Now, the battery. I have had 6 batteries in 6 years, and its mostly to do with discharge and not bieng able to bring it back. I had invested in a C-TEK battery cycling charger and i have never had an issue since. I went to an optima spiral cell sealed battery, on its side so i could get a bigger one in there. You pay a little more for a spiral or a calcium battery, but imho, its worth the outlay for piece of mind, and the warranty that comes with it. remember to invest in a cyclic trickle charger though, will do your battery wonders mate.
Thanks for the post mate, so the optima's are fine to have laying down, well thats handy to know. Thought i was gonna have to mount it differently because they are a large battery. I already have a C TEK charger, usually have it on, just surprised after a week my battery was flat.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
