 HKS SSQV blow off valve. Hollowed out catalytic converter. 3'' JDM catback.
Compression is between 145-150 on all 6 cylinders. Metal headgasket. Nismo lightened flywheel. New intake plenum gasket. Timing belt/waterpump/idler and tension are all in great shape. Almost new ACT clutch(good for 400hp). Iridium spark plugs. New OEM thermostat. New air filter. HICAS lock bar. AC and HICAS were removed
I just bought my car yesterday and realized some black soot and the smell of fuel while drivin I was told this mean my car is runnin rich.... How do I fix this help plz
https://www.sau.com.au/forums/topic/403716-r32-gts-t-running-rich/
Atmo Blow off valve + stock ECU (without tune) is a recipe for disaster (running rich, stalling etc).
Without a functioning cat, you will find alot of black soot on your bumper, I hope you look forward to cleaning it regularly.
I'll hazard a guess that this is your problem, too.
Essentially, the stock rb20 has a pipe that recirculates the released from the BOV back into the intake to be reused. When you remove the pipe or run an atmo BOV, your ecu still thinks the air being released back into your intake and adjusts the air/fuel ratio accordingly. Regardless if the air is there or not it will distribute the fuel, which is why it's running rich. Too much fuel for the amount of air going back in.
The remedies are either getting a stock bov and recirculating pipe or getting your car tuned for the new BOV, from which it will no longer make the assumption that the air released by the BOV is going back into the intake.
Edited by Truffles
Sorry to hijack, but i have a 260rs (R33 GTR) stagea and it has twin atmo BOV, stock ECU, aftermarket boost controller, SAFC, turbo back exhaust system and everything else is stock.
The SAFC is set to default settings (no adjustments have been made, just in read mode). And i get heaps of soot on my tailgate, a bugger to clean.
Anyway i am wondering where the stock BOV is located, and also where the plumb back hoses/s are and go. I have an R33 GTS-T and that is very different in its setup.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
