Hey guys, I have an ergonomic issue which I wanna run past you guys to ask for some opinions/experiences. I'm 6'2" (190cm ish) and my knees touch the bottom of the steering wheel and I also have difficulty heel and toe-ing. I'm currently running the stock seats and airbag equiped steering wheel in my R33. So I was wanting to ask what are the best options for me from others that may have been in the same boat before.
https://www.sau.com.au/forums/topic/404087-knees-touching-steering/
have you tried the knob on the right of the seat? its in front of the lever that reclines the seat, it lowers the front edge of the seat, i had issues with my legs hitting the steering wheel till i found it
might not be the same issue though...
it may help, although you are a lot taller than me...
I'm the same height as u and in my r33 gtr I have no issues, and I'm pretty sure when I had my gtst I didn't have any either.
Do u have an airbag steering wheel? If not then get an aftermarket wheel and quick release hub to push the wheel further out and up to give u extra room
Move your seat back.
Lift the wheel up (via adjustment).
lol.
The stock wheel was originally made for Nissan Buses, large. Non-gtr seats are also from the same Buses and sit very high...
Hard to do much about the wheel and remain RWC compliant. But you can change to GTR seats or Ark Design / Recaro / what ever with Bride Rail and get you much lower than the stock GTST seats.
Yeh I have maxed everything, the steering position and seat position etc.
Oh really?! :O Hm I'll try fidling with the seat again but yeh pretty sure it's maxed at it's current position. Yeh my steering wheels an airbag one xp Edited by Tadahisa
R34 with sunroof is shocking
even with new seats and ultra low bride rails its still to high up , got leg room now still hit steering
At 6'2 and not small frame
I'm so sick of it I'm ready to bolt straight into the floor pan minus the factory pickup points
Just about driving from the backseat !!
Damn poor design
with a body of a usa nfl football player no way lol
I went to buy a viper in usa and my shoulders hit the window before the door would close , unless the targa top was off no way to fit
The new ford falcons are worse to enter the roof line makes you fold in half before entry haha
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
