I don't really know, I havnt heard back from the guy I baught them off
Havnt touched the old 33 for a few days as I've just moved to ballarat
It got it's first big drive from albury to ballarat 450 km and didn't miss a beat
Looking into ideas for the wide rear end still do I buy a kit or flare
Anyways near future should bring answers
Are they a reliable setup
Stock rb25 on e85 300-350kw as reliable as it gets, easiest cheapest option. Go the 30 if you want moretorque but personally i cant fault mystock 25 with 320 in my drift car.
I was thinking that
I baught a set of 1000 cc injectors and was planning on tuning it to e85 and leaving it at that until it pops
In still building an engine but it but it will be done over the rest of the year so it won't destroy the pocket
Time to attempt the gaurd rolling today let's see how it goes :)
I was thinking that
Ye thats best way drop a stock 25 in get the car going then take your time build whatever you want. E85 good tune , change oil after every track day it will last ages, mines been going for 2.5years so far on e85 and a year on 98 beforethat.
Note that that's not actual ride height I just popes the coilovers put to see how the wheel tucked
I think it will do for now after I toutch up the paint and il put a wide body on it when the cage is in and I repaing the shell
Shows good maintenance pays off hey!
Im hoping mine will last until the end of the year
RHD have widened rear fenders, think from memory 1200 shipped but I might be wrong. Same as standard but flared. Look good. Think D Max also do a widened rear pair too.
1200 that's big coin you can get gtr style wide guards in melb for under 500
Really? Where from mate? Not doubting you , just interested for my own build! PM if you don't wanna post in here.
I'm guessing like anything cheap means lower quality
For for what Im doing that's all il need
Something that's relatively cheap also makes it Easyer on the pocket once
You brake it as if I broke a $1200 gaurd by kissing the wall my mrs would be chasing me down
the main straight with the tyre iron
Ah yeah I've seen those ones! I almost bought them a few months ago, but was unsure of how they'd line up, I'd they'd need filler, and lots of work to line up!
If you get them let us know how they fit!
  • 3 months later...
Haha just saw your reply...few months later lol!
Did you en up getting these fitted? Or weren't they any good?
Guess what I was getting at with lots of work is that often by using cheaper parts lots of modification is needed to fit them. I was lucky enough to get my hands on a genuine 400r front, no modification was needed at all. Lined up on a dummy fit first time! So yeah, the price difference can be a big thing, but most times I'd rather spend the extra coin (if I can afford to) and reduce the labour/fitting times. In my opinion.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
