May have to write a nice letter to Office of Fair Trading as a $660 increase is hideous!
Do it, online quote listed as 1562.00 so guess what.... They can stick that up their a$$.
Will call tomorrow to confirm, but lumleys sounds like the go!
OP is from Melbourne, and i dont think NRMA insure VIC.
My friend has his 34 GTR insured for 50k with just cars. 1yr ago $1500pa, this year they tried to raise to $1900pa, but he got them to agree to $1600 p/a . I was so shocked when they quoted $2k p/a for $13000 agreed value on my stagea.
Hey all, got a bit of info off just cars... Basically Due to weather issues around aus over the last year re- insurance has gone up ( insurance providers for insurance companies) looks around 35- 50 percent.
Just cars, aami all owned by suncorp which took a big hit in the floods etc
Gonna get quotes of lumley spec vehicles anyone else gone with them?
Currently I have Shannon's at $1550 for agreed value $28k, hasn't changed in years.
Lumleys price was for $18k value which is about right, might have to switch as its a massive saving
What are they like with listing modifications?
Only mod is sway bars, $28k agreed value was a quote 4 years ago that never changed just kept sending out renewal, its a tough decision, do I save money now or make some if it's written off. .
will probably save money now. . still undecided. .
  • 4 years later...
WTF, is this for real, this old thread . What type of insurance cover would that have been for, or is that mate's rates.
The best Lumley's could do for me was this, Feb 2017
Autech 350s 6 sp
Original quote $ 2, 786. 00,
Amended quote, $ 2, 349. 20 (after a firm get the flying fu#k away from me). There was no third offer. Lol !!
Comprehensive cover,
Value $20,000, (I wanted replacement or $ 30,000 + )
$1000 excess,
No salvage rights.
That would mean in affect that if I had this cover at the quote I was given by Lumley's, first off I'd be feeling pretty riptoff n broke,
Secondly after just 5 YEARS they would have charged well over the odds in my view and well over half the purchase price of my staggie in the first place. Doesn't seem quite right to me. The ex recons I'm a tight arse,
Rego, green slip and insurance due in six weeks can anyone point me in a better direction than this over blown rip.
NRMA are about $900'ish recently, Shannons similar amount, but thats rating 1, over 40 north shore.
Cheers paramour, I think we both noticed the nth shore part of that picture. I live in merrylands (car is garaged) which has been a very high crime area in the past, ( mostly bikie related, ie ice dealing and shootings ) ,so perhaps that would account for Lumley's outrageous quote. Yeah right!!! So we will try some of the others here in the next few days , see if the merrylands factor comes into play with them. Cheers mate ,
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
