  • Replies 118
Posted Images
The process goes like this:
Buy turbo rb20 32
remove turbo
Replace with standard manifold for increased backpressure
Install straight pipe with blast pipes.
Mig up the diff
Go chuck skidzzz ;)
Still registered as Turbo.
Still get F'd In the A by the 5-0.
Also, you left out the step where you install a BW 3 speed.
All noobs.
I say buy an r34 GTR and remove the turbos when on your Ps. That way once you are off your Ps you can put the turbos back in and decimate all in a 1/4 mile race that will take 60 seconds or so... You just have to make sure the manifold is tough, because you may blow the welds to the intake causing piston rings to fry and your floor pan falling out.
:wub:
All noobs.
:wub:
This guy lives his life a 1/4 mile at a time
Sau, Yes he probably asked a stupid question or whatever he did, but to him its something hard to figure out so he asked you guys for advice, yes he should of used the Search function but yeah. To you it may seem like something so dumb, because the topic probs, been done to death. But you should consider, that hes young like me and just wants to unravel something thats spinning around in his head. Flam him, but help him at the same time. Otherwise hes just gonna ask the same question again, just with different words. So put your head in.
Where was this support when I first asked about getting a R34 for my first car? Barely got any replies :(
But seriously to OP, if your genuinely non-trolling and want to get a 34, get yourself a GT or 25GT (correct me if I'm wrong guys, the 25GT is the RB25DE?). It's non-turbo and a good car to drive. My 34 in my sig is my first car, have driven with cops, tailed to and from and never have I been pulled over once.
If you're serious about getting one, I'm happy to give you a lift in my free time so you can get a feel.
And to answer your question, the only R34 you can drive on your P's is the GT/25GT. Pretty much the same with the GTT but without the 3 center dash gauge, exhaust system may be a little different and other little mechanical things that won't really matter to you at this stage. I'm not going to go into the GTR's since that's all I know for now.
And about the cop scanner, LOL. Never knew Need For Speed radar technology existed in real life. But if it does exist, then I'll be damned :domokun:
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
