  • Replies 118
Posted Images
The process goes like this:
Buy turbo rb20 32
remove turbo
Replace with standard manifold for increased backpressure
Install straight pipe with blast pipes.
Mig up the diff
Go chuck skidzzz ;)
Still registered as Turbo.
Still get F'd In the A by the 5-0.
Also, you left out the step where you install a BW 3 speed.
All noobs.
I say buy an r34 GTR and remove the turbos when on your Ps. That way once you are off your Ps you can put the turbos back in and decimate all in a 1/4 mile race that will take 60 seconds or so... You just have to make sure the manifold is tough, because you may blow the welds to the intake causing piston rings to fry and your floor pan falling out.
:wub:
All noobs.
:wub:
This guy lives his life a 1/4 mile at a time
Sau, Yes he probably asked a stupid question or whatever he did, but to him its something hard to figure out so he asked you guys for advice, yes he should of used the Search function but yeah. To you it may seem like something so dumb, because the topic probs, been done to death. But you should consider, that hes young like me and just wants to unravel something thats spinning around in his head. Flam him, but help him at the same time. Otherwise hes just gonna ask the same question again, just with different words. So put your head in.
Where was this support when I first asked about getting a R34 for my first car? Barely got any replies :(
But seriously to OP, if your genuinely non-trolling and want to get a 34, get yourself a GT or 25GT (correct me if I'm wrong guys, the 25GT is the RB25DE?). It's non-turbo and a good car to drive. My 34 in my sig is my first car, have driven with cops, tailed to and from and never have I been pulled over once.
If you're serious about getting one, I'm happy to give you a lift in my free time so you can get a feel.
And to answer your question, the only R34 you can drive on your P's is the GT/25GT. Pretty much the same with the GTT but without the 3 center dash gauge, exhaust system may be a little different and other little mechanical things that won't really matter to you at this stage. I'm not going to go into the GTR's since that's all I know for now.
And about the cop scanner, LOL. Never knew Need For Speed radar technology existed in real life. But if it does exist, then I'll be damned :domokun:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
