anyone know what the settings for Xspurt 1000cc are? using a power fc with stock regulator, was given info on the deadtimes and at 14v its 0.990, thats all i have.
my old nismo 555's were - 62.5% 0.18ms
what should the new settings be? 37% 0.990ms
https://www.sau.com.au/forums/topic/405065-injector-settings/
I did have the data sheet here but I can't find it. Just give Aznew (Injectors online) a call, they are quite helpful. If you have any issues I can ask them today, I have to go and pick up one of the new Walbro 416's they got in stock for me.
Thats where i bought them, i asked about it and they said all they have is the deadtimes list, so that has 0.990 at 14v
deadtime is same as latency is that right? so its 0.990m/s
if thats right then i just need to work out the first part. What are they charging for the walbro, i didnt know they had them, ive seen them for $190.
They are around the same price then.
I have the dead time report here, that is correct for 43.5 psi but it will climb exponentially the higher the fuel pressure and if the voltage is lower. Most tuners will have used ID's and ev14's before so I doubt you will have any issues.
i was hoping to put them in and start it up this weekend thats all, ive sent an email to the tuner, so hopefully he responds by the weekend.. :yes:
looks like i wont be using the stock reg, just got a turbo smart one, do you still use 43.5psi with 1000cc injectors or do they prefer a bit more pressure?
Standard injectors are 370cc and .63ms
Your new injectors are 1000cc and .99ms
370/1000x100 = 37%
.99-.63 = .36
There's been some debate about the standard injectors latency so I'm not 100% sure about that but it should be close enough to get it running.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
