I've used some. I'll take some pics later and show you my result. I'm pretty happy with it, had to sand out kerb scratches first though. I've got some stone chips as well but I didn't want to go do it since it would look blotchy with a touch up brush or pressure can. Since your's is black, I don't think you'd need to prime it first but it would be recommended. I didn't prime mine so theres slight tone difference, but will be respraying it again to give it another coat.
If it's on metal panels, I personally wouldn't touch it since it won't be an even finish. I touched up my front bar. Head down to Autobarn and you can pick up either a little touch up paint with brush or a pressure can.
https://www.sau.com.au/forums/topic/405228-touch-up-paint/#findComment-6452840
  • 3 weeks later...
  • 4 weeks later...
Sorry to butt in but I thought I'll join as oppose to start a new thread.
Has anyone used these guys before to do touch-up paint jobs? - http://www.propaintauto.com.au
Looks like good results but not too sure if it'll be cost or even time effective.
https://www.sau.com.au/forums/topic/405228-touch-up-paint/#findComment-6530281
Unless it's a special black, e.g. with pearls or matte. The closest black from your closest auto shop will sort of do the job if you're not looking for perfection. Otherwise, special paint shops will fix you a color to match your car's color code. Can be put in a spray can, tin, nail polish bottle, etc. Of course it will be more expensive.
If you're using a spray can, you can also shake well and spray some into the lid and use a small brush to touch up spots.
As for application, just make sure you have cleaned the area well and when you touch it up don't do a rushed job and try not to coat over or "fix" too much as the ingredients will end up hurting area surrounding more than you actually fixing it. (It will take off your clear coat).
Also make sure that you have a clean micro fibre cloth with some polish handy as soon as the paint is dry protect it. Usually touch up handy men will have some sort of cream polish, so it's not too harsh. Along with a small drill polisher, which if you have, great!
https://www.sau.com.au/forums/topic/405228-touch-up-paint/#findComment-6539002
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
