Hi All,
another question about my stagea. i am not sure what stereo options were available in japan for the 260RS when it was sold. I found a massive bundle of wires that started behind the stereo and ran all the way to the boot of the stagea and ended tucked into the left side of the car (LHS rear wheel area). connected to nothing at either end, but it seems there was a cd stacker behind the left boot trim, now just empty space.
When it arrived here it had been decked out with aftermarket system, AddZest (Clarion). It had the DVD Head unit with slideout screen and hideaway box/receiver, 5.1 surround component and TV Tuner.
I have managed to get most things working fine however 2 things are left that are bugging me. The radio tuner's range is not expanded and i wanted to know what i have to do to expand it to tune all australian radio stations.
Also, how do i receive TV signals/channels in australia (melbourne). Does it have anything to do with the FM expander? or is it something else entirely? Can anyone help me understand what is required to get the TV Tuner (Addzest/Clarion) box to display. All i get is static when i try to find a signal.
Edited by THRLLR
https://www.sau.com.au/forums/topic/405357-tv-tuning/
If its the tuner from japan it wont work here. It is a different system. Replace it with an aussie one and feed that into your screen. You can still use the aerials that were connected to it and it has nothing to do with a band expander. If you want to expand your radio you need an FM band expander with the 2 pins and it plugs in line with your radio antenna and is powered up by ACC.
https://www.sau.com.au/forums/topic/405357-tv-tuning/#findComment-6455438
Awesome much appreciated. i thought as much about the tv tuner but i couldnt find anything to tell me otherwise. Does it have to be a Clarion unit? or any tv tuner?
Thanks heaps for the info it all makes much more sense now
https://www.sau.com.au/forums/topic/405357-tv-tuning/#findComment-6456218
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
