Hi Guys,
Has anyone earthed Pin 60 from the PFC in order to fix the dreaded R32 GTR Misfire issue?
I just want to know, when you earthed it, did you cut the wire entirely and earth it straight from the PFC? Or did you splice in an earth?
I tried splicing in an earth and the car started to idle very roughly and i'm a bit cautious to cut the wire entirely to test a direct earth.
Thanks,
Taran.
https://www.sau.com.au/forums/topic/405358-r32-gtr-earthing-pin-60-on-pfc/
I was told by other skyline people that running other than OEM coil packs can cause the hiccup. But I don't think so... And another thing I've been told was that the power fc needs a constant voltage and if it drops below that then it causes the hiccup.
But I can't confirm or deny any of that sh!t.
Alright guys. I grounded pin 60 directly using a very clean ground and it failed. It made the idle really lumpy and rough so now i'm back to how it was before.
Anyone have any other ideas?
The capacitor sounds interesting. How would we implement it?
Update. So i drove the car yesterday and the misfire is gone. Will have to drive it a bit longer to confirm it but so far so good. If it's permanently gone then it means it was the ignition fuse, near where the 4wd fuse is under the bonnet. The new fuse i picked up from SSS Auto looks like a newer type, it sticks out a bit more and the fuse link looks much fresher than the previous one. Perhaps this could have been it? What kind of fuses do you guys have in yours and what model GTR's do you have?
The fuse thing could be the fix. Maybe after X years they get brittle.
I put a USB charger in my ciggy lighter, and when u plugged a USB cable into it the fuse blew. Thinking it was a broken item to start with, but tested it again with a brand new fuse, and its been fine ever since. So it is possible that maybe the fuses are causing a bit of resistance?
i think so but its not at all bad. ill be cruising along everything perfect then BANG the car will just kinda like hit limiter or something scares the absolute shit outta me. then thats all, it goes without a trace. does it once every 2nd drive say. just got new 30a fuses the old ones have alot of green scum on the copper through the clear plastic.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
