  • Replies 58
I deleted all that shit, she pissed me off that much. Was many years ago, lol.
And now she has put on more weight then I have :P
Hahaha gotta love that :P
Actually, I think some are on an old phone of mine. Unfortunately someone I don't talk to any more has that phone. Lol
So they may still find the internets one day? :D hahaha....
Alright, that's enough of all that. This is a PUBLIC forum, after all, so no more pics of scantily-clad girls here - there's a section for that already...
Nibibo, if you are serious and want to contribute to this forum and its community, your best bet is to actually make an effort when you post something. Tell us about yourself, what you want to get from the forums, what kind of car you drive (or pushbike/skateboard you ride), where you work/study, etc. And if you have posted a question, there's no need to repost it again and again in other sections of the forum. Use full sentences, provide some decent information (especially if it's to do with problems you are having with your car), and pls dunt typ lyk dis, okay? Your English doesn't have to be perfect, but at least make an effort...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
