so im looking at buying a set of these achilles 123 semi's. as there a street tire i dont think there really a real semi slick but thats what they call them. so im wondering if anyone has used them and can tell what there like in the dry and wet. there pretty cheap around $220 each. trying to compare them to the rsr and ku36 with a better tread wear.
Dunno about the semi sliks but my mate just replaced a set of Achillies road tyres on his wifes commodore that did less that 5,000kms before they were rooted... I think they are a pretty cheap shitty brand.
I was looking at trying them too... Most I've asked said they are on par with the other two choices... There are drift cars and track cars using them successfully, they are a street tyre like the others and should be fine.... As for the commo wearing them in 5000km, well it's a commo.... :P
I don't know their semi slick at all, but for a cheap tyre I was very impressed with their street tyre's grip. The extra wear Chris was seeing might be related to being softer/better grip than the usual chinese rock-hard tyre that lasts for 1billion klm but has no grip.
Nope, they will be along the lines of the KU36 and RS-R, a real grippy tyre for street.... I assume these will suck in the wet too.... My KU36 have done over 5000kms and are only wearing due to no wheel alignment since suspension work, they have a similar tread wear to the 123s I believe
Don't be fooled into getting these tyres, I have these horseshit tyres on the R33 I just bought, the rears are 275 wide and the car is stock, and I have crap all grip.
I ran smaller 255 KU31s on my old 240rwkW R33 and it provided more grip.
not to mention I have a friend with a mirage using the same tyres and he lights up 3rd gear with ease, well he is running an EVO 5 motor but that's not the point lol
Edited by johnnilicte
And yet SimonS14 and a couple of the other drift guys all rave about their grip?
it's like someone saying Linglong tyres provide hectic grip, try them out for yourself LOL... yashimash!
Are you sure you didnt use the achilles atr sport? because Ive also used the 123 and they are on par with the rsr in terms of grip.
Achilles 123 aren't sold in a 275 tyre as far as I'm aware also... :/
Danny Vahoumis drifts with the Achilles 123 also and it's apparently a pretty decent tyre.
I have 123s on my Evo 8 and I would recommend them to anyone. Great tyre for the price. In the dry they grip better than my toyo r1rs and federal 595 rsr. For the fella that spins 275s like the car is 500 horsepower... Your car suspension would be set up like a pile of sh*t.. That or you're driving in the wet clutch popping every two minutes.
Probably is too, just bought the car and it's running some rubbish pedders comfort shocks & springs, soon to be removed and put on eBay.
As for the clutch popping every two minutes, I'm not 18.
Can you confirm you're running 123's? What size are they if you are, cos you're not running 275's.
I'll look when I get home, they provide very bad lateral grip I can tell you! The car would come out around corners in a tight roundabout with some gas.
Could be a heap of reasons for that though!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
