  • Replies 224
Damn was really looking forward to this as i enjoyed it so much last time. but cant go this time sad panda saving up to go overseas end of year plus need new tyres haha god damn :(
This will be such a awesome event just like last time Have fun fella's
Can i neet up with a committee member some time an pay cash in full? Got it here and saves me leavin work early to get to a bank
where do you work? ill try and meet up
also note this has been exclusive for 2 weeks already and is open to friends as of now
it will get merged into general section later today
OK Sau General populace SAUSA is having a passenger track day, this has been exclusive for the first 2 week to allow members plenty of time to get their names on the list
we would now like to invite anyone to join us for the remaining 5 spots
General recap
Spot NOT secured until Deposit is paid (NON refundable)
Deposit needs to be in by the 25th August or contact one of the Executives
The remainder is due on September the 25th
FREE Bqq will be provided so we need to know if you're coming
passengers WILL be allowed in your vehicle (passengers require a long sleeve cotton shirt and helmet),
Track timers ARE available to hire $50 per person
Deposit can be paid via Direct Deposit
SAUSA Payment details
Name: Skylines Australia - SA Chapter
BSB: 105 192
ACC: 028 822 340
