My car is currently getting some tuning work done on it and they noticed a mild coolant leak from under the intake manifold, they pressure tested it and it came up fine but it certainly is leaking. I'm guessing the issue is because we reused the intake gasket from the old motor because it was only ~5000kms old.
Taking the intake manifold off is a gigantic pain in the ass, I'd say putting an engine in is less work so I want to know is if I use some kind of sealant around the edges where it is leaking am I going to have any success, if so what kind of sealant should I try?
I figure it can't exactly make it worse, buy me some time until I can remove it myself.
yeah there certainly isnt a lot of room under there,you might have to bite the bullet and take the manifold off as i cant see any kind of sealant staying in place as you would need the surface to be really clean for it too adhere
Rolls urs is easy. I just bolted mine back together after a leaking coolant hose. heres what under an rb26 plenum looks like 2539a276.jpg
Heres after replacing hoses, cleaning and new tomei gaskets.
Good thread hijack yeah?
And back ontopic, yes use a slight smear of sealant if there is coolant passing through
i had the same problem when i fitted my after market plenum , hadnt driven it for a few months , and when i finally got it on the road i started to notice a leak . thought normal gasket goo would of done the trick on the first initial install . had enough and endured the pain in the ass of removing it , i simply just loosened mine off and got some ultra strong sealant (red type silicon based) from supercheap , applied it with a little brush to both sides of the gasket and let her sit over night , no more leak . but im guessing your running the standard manifold?
id get a camera phone and take a few photos underneath like i did to determine exactly where , to be sure before you go into removing the manifold.
good luck
It is an R34 NEO rb25det with an R33 S2 intake bolted to it, so I'm guessing the rb26 intake is quite different DVS JEZ?
Are there any coolant lines running through the intake manifold on an R33? Or is it air only? If so where would the leak be from?
The leak is at the front of the engine, sorry I can't be more specific than that.
KK so it could be from the gasket then.
My mate offered to change it this week for free! win. Just got a 15% payrise at work with 7 months backpay so I think I will give him a decent lump of cash for it, more of a prick than removing/installin an engine imo.
Lump of cash sounds fun :)
Neo and R33 manifolds are supposed to be different.
You just have to replace a stud at the front and then it bolts on, or could be super dodgy and put a nut on the end of it.
I bolted R33 everything onto a Neo motor, kept the neo coils + CAS and everything else bolted on no issues.
Edited by Rolls
oh, I was fairly sure we sized the gaskets up and they were off by a little bit more than that.
Also R.I.P.S had to make a custom plenum for a guy because they were different and he had to send them his Neo manifold.
I will have to investigate now.
If you could find out more that would be fantastic. I was told by a few workshops the manifolds were basically a bolt on job though.
If the gaskets were off surely I would be having massive problems also?
Edited by Rolls
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
