Hypergear?
Kando?
Check them out in the forced induction section
Yeah as mentioned hypergear and kando turbo's are not quite close enough, although the hypergear ATR45 is close but on border being close enough.
the 3540 isnt overly expensive, compared to some of the smaller ones ie gt30's.
have you thought about going to a 3788? slightly bigger but uses the large frame bearing cartrige and T4 housings. good for 450-500kw at a stretch.
or pickup an ex BA/BF xr6 turbo and change to the normal garret housings?
That is a good suggestion, there'd probably be a few second handers out there you could pick up for cheap. They come with a 1.06 turbine housing standard don't they?
How much power is this car owner wanting to make and is that power on 98 (assuming so). Precision turbos are looking pretty good from the latest couple of results in the precision turbo thread. They have the option of bb or plain depending on your budget as well
Edited by Mitcho_7
The twin scroll setup on jez's car had pretty good response for the power IMO, but then again he was flex fuel.
How much boost is the owner of the car wanting to run?
Whatever you decide, street to track has great prices on any Garrett turbos (he can probably get precision turbos aswell) and they will arrive within a week. The aud is great at the moment as well!
Edited by Mitcho_7
I've had a ATR45 in.82 rear agers ago. That core is interchangable with a Ford XR6 BA turbo.
Planning to run between 18-24psi as it was tuned running 22psi mind you the engine has a fair bit of internal mods hence why the plan is to go for the large turbo.. We did look at the precision 6765 with a .8 rear. Which would give 500rkw which would lower the boost level down a little with more to play with.
Btw Thanks for all your imput guys.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
