Hello,
You need a pink slip - which is a mechanical inspection, can be done at most mechanics (around $35).
The mechanic will fill out paperwork and electronically send it through to the RTA. Once this is through, you will then be able to renew your registration by either going in to the RTA or online.
Then you need to also renew your green slip. Think of this as 'people insurance' for those in and around your car while you are driving.
Hope this helps.
And that "Green Slip" or "CTP" insurance (Chris mentioned above) should be in the mail to you Ricky.
If you're insured with Shannons, Shannons has their own "CTP" "Green Slip" at a discount rate - undercutting other insurers.
So you can shop around...
you will only need a blue slip if rego has lapsed for more then 3 months, Other then that, your pink slip and CTP is all linked, THey will notfify eachother so its in force at the same time.
you can do CTP over the phone and they will give you a recipt number, YOu wrtie that down and put on widnscreen if your rego has lasped for a few weeks.
Then mechnic will test brakes and quick look over, as above about $35
Stupid question, but comprehensive doesn't include CTP does it? I'm with NRMA.
Roads & Maritime (aka RTA) wants 3 things off you...
1) Registration Papers with $$$
2) CTP (green slip) that has already been paid - this covers people injured in a smash. It will have been stamped after payment.
3) Pink Slip or Vehicle Inspection Slip after your car has been inspected at an authorised station/mechanic; and this has been forwarded to the RMS anyway (before you get there)
After 3) the vehicle inspection has been done (aka pink slip), as Adam and others have said, you can register online. :)
check your rego papers to see if an inspection is needed, I didn't need one on my series 1 r33 because it was complianced in 2007 and is classed as 2007 model to the rta, so fell into the new car rule of not needing an inspection for 5 years, so you may only need to get your green slip
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
