!!!!Need An GOOD Priced Exhaust Shop For Fitting A Dump/Front Combo Pipe!!!!!!!!
Guest RedLineGTR
Okay, I need peoples help I need a dump/front combo pipe fitted to my r33 gtst, most exhaust places say they can fit it no problem some are willing to charge me more since they aren’t sure of the time it will take etc, some exhaust shops say they have worked on r33's before lalalala and have done work for other performance shop, but I have had little things done by these (recommended places by performance workshops) and I have gone away with a product that I’m not happy with.
I need someone around this side of town (chadstone, dandenong etc) that:
- Knows R33 Skylines or skylines in general.
- Has fitted a dump/front pipe combo or something custom before.
- Has half decent prices (as long as the job gets done well).
- Not located on the otherside of town.
Any recommendations and possible names of people that have some knowledge and some good service, would be very grateful!!!!...unless someone has done it before and has the tools the get it done??
Thanks for your time. Cheers Rob
Guest RedLineGTR
Thanks for that meshmesh, if all else fails i will have to drive quite a bit from where i live, hopefully someone will have one around my area if not then i'll pack my picnic and have a drive to Campbellfield. Thanks for your post, Cheers Rob
Rob are you after a split dupe pipe / wastegate pipe pff the turbo? or do you already have one.
i believe the rb25 turbo has the wastegate flap in the dump pipe so you can only get a 3" flared pipe from the end of the cast section to the cat.
Until now ;) i have a friend who owns and exhaust shop and is designing custom split dump pipes with seperate wastegate pipe and the wastegate flap inside it. Hel also does turbo manifolds etc and is very good we send all our cars there and always happy customers :).
rob speak to me on msn if you don't understand what i just posted lol
or Call Exhaust Worx
97611124
Les is the owner there.
But its in Bayswater but you know all the good workshops are in the south /east / eastern suburbs :D
cheers
Guest RedLineGTR
I already have one, i have looked at both but found the prices to be the main difference.
I have a flared pipe so to speak, the only split ones i have seen have been in stainless steel (worries about it cracking) and the price range was abit too high, the split dump even in mild steel would have good benifits as compaired to the flared one but, found a good price for this one and the split type dump wouldnt make too much of a difference in such mild modifications atm.
Until now :D i have a friend who owns and exhaust shop and is designing custom split dump pipes with seperate wastegate pipe and the wastegate flap inside it. Hel also does turbo manifolds etc and is very good we send all our cars there and always happy customers :).
Ah sweet, someone to talk to about some future projects etc and maybe get some prices.
Nah i understand what your saying if i need anymore info i will msn you, at school atm ;)
Thanks for the reply :) :headspin:
Guest RedLineGTR
exhaust shop
try Matt... Pushead got him to install his dump/front pipe combo.
matt dosent work their anymore..moved on somewhere...might go to DAALDER exh. in Box Hill but wasn't too confident in the conversation at hand.
well i can reccommentd:
Blinky's Brakes and Exhaust in Dandenong (sth gippsland highway)...
they did my and coco69's intercooler piping and gave me a price $300 cheaper than ice performance! trust me they are cheap and did a fantastic job.
Ask for stuart and tell him Warren sent you (the guy with the blue r32 that got his intercooelr piping done)
good luck!
PS my dad and i fitted my front/dump by driving onto car ramps and doing it fron there. hard work but free! another option if you are good with a spanner or two...
Guest RedLineGTR
Do it yourself and save $$$ Its just a coupla bolts and an oxy sensor. I watched mine be professionally installed (30 mins... if that) and was disgusted when I got the bill.
I have tried, but you need some specific sockets that are nice and thin, i had a look in a car store to see what they have, found some that would work but i would end up spending nearly the cost of the install itself. Cheers Rob
Thats the biggest argument for doing it yourself! Next time you need to install some hardware under the hood the tools will already be there and pay for themselves! If the tools are cheaper, you save money. Even if the tools are only $1 cheaper you're still going to save money (I mean to sound like a tight arse, I'm making a point). You'll also know with 100% certainty that the job has been done properly, and working on the car is fun!!! :cheers:
Guest RedLineGTR
Thats the biggest argument for doing it yourself! Next time you need to install some hardware under the hood the tools will already be there and pay for themselves! If the tools are cheaper, you save money. Even if the tools are only $1 cheaper you're still going to save money (I mean to sound like a tight arse, I'm making a point). You'll also know with 100% certainty that the job has been done properly, and working on the car is fun!!! :)
the way things a going i probably will :) (its all your fault :jk: ) when i was doing it myself i pretty much got all the bolts off except for 1-2 bolts which i couldnt reach. You’ve inspired me !!! lolz
Anyone need some dump/front pipes fitted by the way??? if i get mine on :) lolz
Guest RedLineGTR
be careful though...
we snapped a bolt goping into the turbo and had to drill it out - BIG pain in the ass!
thanks for the heads up, heard about that happening a little while back...when i tryed it myself sprayed some WD40 just in case and pretty much most of the bolts came off fine except the ones i couldnt get too :) Cheers Rob
my issue was:
tightening bolt... tightening bolt... tightening bolt... just one more turn... SNAP!
followed by abusive swearing!
but lucky it was the bolt that was easiest to access.
also because we drove the car up onto car ramps we could get to 3 bolts from the bottom REAL easy. might be worth a try.
good luck!
Waz.
Guest RedLineGTR
my issue was:
good luck!
Waz.
Thanks man I really appreciate the info. Cheers Rob
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
