Guys,
Have noticed when I do long trips in stagea every now and then my boost will.go from 9/10 pound to getting restricted to 5pound till I reset ecu via turning off car. No dash warning lights and yes they work. Any ideas guys??
Edited by joshm35
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/
I had a problem with the Boost Solonoid where instead of getting 13psi max boost I would get only 7psi.
My problem had no CEL light and was solved each time by turning the car off and restarting. The cause always seemed to be giving it a few revs up a particular hill.
I changed my Boost solonoid and the problem was solved. The Boost solonoid sits on the passenger side of the car under the plastic engine cover. It is bolted to the side of the plenum and has 2 small rubber hoses running out one side, 1 to the intake and 1 to the turbo actuator and one hose rinning to the front of the car that connects via a T piece to the boost sensor on the intake.
I believe you can clean a solenoid but I did not try that.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478256
If the solenoid is blocked it will lower the boost, if there is a leak it may go higher causing the ecu to pull it back.
The hose from the solenoid that T's into the boost line has a restrictor in it. If it has been replaced that could make the boost rise too high causing the same issue. Have you changed the exhaust to 3 inch? that would cause it to run higher too.
A way around it is to trick the stock map sensor into thinking the pressure is fine, you could use a small pressure regulator if you wanted, set to 12psi, but I would be getting a better boost gauge first.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478291
i removed the factory one and replaced it with a turbosmart easy 5 mins fix. Boost comes on much better and smoother now.
QFT.
Buy boost gauge
replace with a turbosmart(or the sort) set it to 14psi or whatever the boost setting is and bypass the lines for the standard solenoid. Leave the standard one plugged in to avoid CEL. problem solved.
Edited by Sunkist
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478382
Cheers
Andy
This sounds exactly whats going on. Do you know the price and numbers of a new solinoid?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478525
Standard hoses and exhaust
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478527
for now? its what I would be doing permanently.. keeping or replacing the solenoid is not going to fix the factory safety drop in boost. it is spiking with the cold weather and/or not allowing the car to warm up before boosting. mine used to do it all the time and it pissed me off. the only way to get around it is by bypassing the solenoid with a manual/electronic boost controller.
once again: problem solved.
plus i cant imagine the worth it:price ratio for a new solenoid, which is most likely not going to fix the issue.
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6478798
No, don't know the cost. BUT either take up Scotts offer or get an aftermarker boost controller. Even with the wastgate actuator spring Mod the car felt stronger on initial boost when I used the Greddy Profec B boost controller. It bypasses the factory one so no more problem.
Cheers
Andy
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6479728
yeah i thought of keeping it though it's one less thing i gotta worry about second guessing me bleed valve :)
Just keep it in the glove box or boot hiding spaces, if the problem ever occurs plug it in and drive home?
https://www.sau.com.au/forums/topic/406537-m35-boost-issue/#findComment-6481080
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
