hey gents, noticed today (its bloody cold in melbourne) that my heater is pants. its takes ages to get warm and even then its not 32 like is says on the air con.
also when i press the auto button the ac is not making it get any warmer any quicker!
i know the heater works because before the radiator replacement it was red hot! any ideas?
94 r33 gtst.
https://www.sau.com.au/forums/topic/406561-heater-issues/
Hey bud,
I've had a similar problem where it took so long to get the heat, but also even if i was to put it to 28degrees it didn't feel like it. I had to replace the waterpump, after that everything worked fine. But as John said make sure you bleed your system.
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6481398
yea the engine is warming up fine. had a new radiator put in about 3 weeks ago. because the car was overheating.
so your saying bleed the cooling system? i know the thermo is good it was changed about 15 days ago lol.
right to bleed i usually put a bottle in the neck of the radiator to get the level above the bleed screw on the intake manifold. i then unscrew the bleed screw and poor water/coolant in to the bottle until it pours out of the bleed screw is this correct?
Hey bud,
ive got a new water pump to be fitted when i have my timing belt and tensioners changed. just gotta fin someone to do it.
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6481422
I'll tell you how I bleed it as that is how I did it on my 31, 32 and my BMW 320i. (ASK AROUND JUST TO BE SURE HOW OTHERS DO IT)
- Car is cold, open radiator cap and turn car on.
- Wait couple of minutes and put the heater on hot and full blast
- You will see bubbles coming out of the radiator - rev engine slightly once or twice (only by 500rpm)
- Wait until no more bubbles are coming out put radiator cap on
See if you can have somebody look at the water pump asap, because i've had a similar problem then water pump was completely gone then radiator started overheating
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6481532
the r33 has a bleed screen near the intake plenum. it's on the drivers side of the engine at the front of the plenum. it has a 10mm bolt at the top of it which you open to bleed the system. this is the best way to do it.
as for the heater, as above, make sure the temp gauge is reading in the middle of the gauge. for best results with the heater, don't turn it on until the engine is up to temp otherwise the car will take much longer to warm up because it has to heat up much more coolant, plus the fact that the heater works a little bit like a radiator, so it actually cools the engine a little bit. the heater core also takes a little bit of time to properly heat up, so it should pump out some warm air pretty much straight away (if the engine is warm) and should get hotter as time goes on.
also for best results, turn the AC off when using the heater (just have the fan going) as the AC will cool the air a little bit.
if it was working super well before the radiator change, but not after, then that may be because of 2 things. 1: air in the system, however just driving around with the heater on should bleed it out of the heater system and into the greater cooling system, so the heater should work fine. 2: the thermostat is making the engine run much cooler with the new radiator. if the old radiator was making the car run hot then any issue with the thermostat may have been masked. so just make sure that the car comes up to temp quickly.
it may also be that the heat tap isn't opening properly (but because the car was running so hot the hotter coolant made the heater core heat up enough), or the water pump is on its way out.
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6481997
air locks make the engine temp go up, but if the air is in the heater core then it won't get hot becuase there is no hot coolant getting in there to heat it up, but an air buble shouldn't just stay in the heater when the engine is running
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6482839
Remember to install it properly, the little metal wobbly bit needs to be up top to allow bubbles to flow through, the original Nissan one has the markings, but aftermarket ones don't. They assume you know what you're doing.
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6484447
check that you have good coolant flow through the heater core itself ie core not blocked?
True that, mum's car was farked... new themostat, new water pump but still no heat, turns out the heater core had like algae or some alien life form in it. I popped off one end, and hose clamped down the garden hose. Pumped it's mum out, there were chunks of gooey shit.
Heater now is good.
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6487744
anyone got a quick way to flush the heater core? its just feckin wierd that it was hotter than the sun on the old rad and thermo and now on the new rad and thermo its colder than michael jackson!
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6487777
disconnect both hoses from the firewall, connect a garden hose to one end, pump it's mum out?
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6487863
nice one brother! should i be expecting to lose a lot of coolant out of this? the sneak barsteward who replaced it when he changed my rad didnt tell me what type to put in! i quote "might need to top her off in a couple of k's just put some water in."
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6487895
heres a question.......
once all the coolant is flushed out with water. how do you get the water out!?
always wondeed this about cooling systems.
i hate them. im a pretty decent mechanic engine wise, but i effing hate cooling systems.
(im a generator mechanic and they where mostly aircooled!)
https://www.sau.com.au/forums/topic/406561-heater-issues/#findComment-6488280
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
