Hey guys got a LINK G4 plug and play here for sale, only selling as I've gone Haltech
ECU is used, however it functions as required. May as well be new for what it is.
Comes in standard R32GTR case
$ 1250 couriered to your door with tracking number
This has been on my race car for approx 18months and has many many hours of tuning on it.
My Rb26 with -5's + extras made 450kw, this tune is onboard and the Link is unlocked.
PM me with queries...
G4 Plug-In Key Features (where applicable)
  • Up to 6D fuel and ignition mapping
  • Precision closed loop cam control (four cam, independent control)
  • Sequential fuel delivery
  • Digital triggering, all OEM patterns
  • Rotary - up to four rotors, fully sequentially staged injection and sequential ignition
  • OEM idle hardware supported
  • 5D boost control with three switchable tables
  • Motorsport features - antilag, launch, flat shift
  • Continuous barometric correction (on board)
  • CAN port
  • QuickTune - automated fuel tuning
  • Individual cylinder correction
  • USB tuning cable included
  • Stats recording into on-board memory
  • Gear compensations for spark, boost and fuel
  • Real time selectable dual fuel, ignition and boost maps
  • Sync and crank sensors can be a combination of Hall effect, variable reluctance or optical
  • Boost control referenced to gear, speed or throttle position
  • Up to 4MB internal logging memory
  • Staged injection
  • Firmware updates available online (linkecu.com)
  • Knock with “windowing” via additional G4 KnockBlock
Quick Tune
Using PCLink, QuickTune is an interactive tuning tool that assists in time efficient fuel tuning.
A graphical display of Target AFR (desired AFR) and Actual AFR (measured AFR) is provided. A dual pointer gauge allows the tuner to quickly see how close Actual AFR is to the Target AFR. QuickTune can be setup to operate over the entire fuel table or just over a particular area.
QuickTune can be used in Manual or Automatic modes. In Manual mode, QuickTune guides you to cell centering and advises you when is a suitable time to make a fuel table adjustment. With the press of a key a calculated adjustment is made. Often only one or two adjustments are required to tune each cell. In Automatic mode QuickTune does all the adjustments for you. This leaves the tuner free to operate the Dyno or perform other tuning work such as making ignition or cam angle adjustments.
https://www.sau.com.au/forums/topic/406576-link-g4-plug-in-for-r32-gtr/
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
