Got my new beast today :)
Hi guys
I just thawt that i would mention i got my new R33 today so if you see a red GTS crunching gears and doing 360`s in the middle of the road please give way cos i am new to it.
BTW its my first manual car and im told that the 18 pounds boost is pretty savage.
I hope to see you all around on cruzes and such and please c`mon over and say hi :)
Lee
https://www.sau.com.au/forums/topic/4067-got-my-new-beast-today/
Hi Lee .... welcome to the warm fuzzy world of SASA.
Even though I don't won a Skyline myself :) .... I nearly did though - does that count?
I only have a crappy little S15 ;) .... check it out at My Site
Got any pics of your ride?
btw be very careful at that sort of boost if you've never driven a manual before .... best of luck and look forward to meeting you at the next cruise.
Welcome SPOOLIN (Lee) Nice choice of car, & colour too!
I'd be a little cautious about running 18psi boost unless the engine/turbo/intercooler etc have been set-up to allow this!
If your car has already been modified to cope with 18psi then ignore the above warning & smile ;) 'cause you've scored a good one mate :uh-huh:
Nightcrawler,
Saw you & your beast on Fri'/Sat' night (can't remember which?) @ the lights on Grand Junction & Sudholz, we were in the family mobile (green 5dr RAV4) turning right from S into GJ. Can't miss those plates of yours mate :)
Lee,
You've sure got me interested now mate :uh-huh: Can you give us any idea on the engine mod's?! Like the turbo it's running :)
You're gunna' have to come along to the dyno day on the 12Oct' then ;)
Lee,
I am new to the world of skylines and manuals as well.
I bought an R32 GTS-4 about 6 weeks ago.
It won't take to long to pick it up, just take your time to start with and don't rush your gear changes.
Hope to see you out cruisin.
Woohoo..........:)
Ive just come back from a few hotlaps (well slow laps actually) around the block and the beast is still in one piece *yay*
Hmmm......enigine mods....Well i dont really want to give too much away at the moment until ive seen the car make the power myself. Oh and if i say too much no one is gonna line me up at the lights:( but i will say that the (OS Giken triple plate clutch) is a bi*ch for slow speed takeoffs.
As for the dyno day i will do my best to get there but it will depend on how my driving is coming along :)
Lee
You'll probably find there will be others on the forum with the same gizmos fitted to their Skylines. All you need to do is find someone with the same bit of gear & ask away :) Assuming they know how it works!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
