Hey guys
Does anyone know of or have used any anti-condensation products? Or if they exist?
I'm really sick of getting condensation on my car every morning and driving half blind until my glass warms up/evaporates.
https://www.sau.com.au/forums/topic/406820-anti-condensation-for-windscreens/
Rainex antifog but in my past its only good on house mirrors lol
Turn on ac and place airflow in recurculated it will dry them fast as hell
Outside rain ex works in mutiple thin layers or glass wax
R34 came with a anti condensation coating factory on side glass ( which is why its a bugger to clean off acid rain lol) i found it on the sales brochure along with two paints same code one hard , one normal ??
Edited by Carbon 34
If you're lucky enough to have the Super Fine Hard Coat, you should also have a cool SFHC sticker on your rear window.
Edited by iwanta34gtr
Not anymore lol the osaka acid rain etched it so bad the dealer used a steel wool pad to try and rid the car of etched glass , which i had to polish out the fine scratches on the rear window :-(
The paint is the super hard as well and after 3 runs of m105 cutiting compound shines like glass again
#1 way to stop fogging up.... keep the inside clean!!! i have no issues with fogging because i clean the inside regularly. It's only if it's really cold and i'm really hot, that it will fog a little. Generally not a common combo...
All the time you're building up oils on the inside glass, windows down driving will speed this up especially...
IMO you don't want to recycle air mode to clear fog. If it starts fogging, and you have recycle air on it's taking the warm air your expelling and circulating that around the car with a cool exterior = fog. I guarantee without A/C, recycle mode will speed up the fogging.
As for A/C, yes it does clear fog very quickly but then it comes back just as quick and generally if you have fog issues the last thing you want is to blast the A/C hahaha.
I go the complete opposite if need be, i crank the heater (which i'd be wanting to do anyway). It doesn't go away as quick but i find it KEEPS it away, plus you're not needing to run the A/C and all the drawbacks that come with that. I find the heating method finds the balance of temperature better to stop the fogging coming back...
But i always have it on fresh air mode, not recycle.
If you haven't cleaned your interior glass for a while it will be FILTHY, if it is even SLIGHTLY smeary, your fog problems are hugely amplified.
Some people will see this as a bit OTT, but this is what i do and fogging for me is VERY rarely an issue...
Get a MF, warm water and dampen the MF. Clean the glass down whilst constantly rinsing the MF. You'll see the water getting dirty.
Do that a couple times until the water is clean.
Get another clean MF and wipe the glass dry.
Now, the last step is to really cut through whatever grime is left (warm water won't do it alone). Get a good glass cleaner like Stoners Invisible Glass and get a Glass MF. Glass specific MF's are very different to paintwork MF"s, but work great (and you'll definitely see them get dirty too). Go over glass with Stoners and glass MF.
Finally, wipe down with another clean MF and from here you will not need any sort of 'product' on the interior glass.
FI's Glass MF system
http://shop.finalins...products_id/210
Final Inspection's glass cleaner isn't out yet, but Waxit sells Stoners
http://www.waxit.com...id=213&Itemid=1
Lastly, DO NOT use your chamois or waffle weave drying towel to clean your interior glass AFTER you've washed the car. That's a sure fire way to make them super grimey. You have to have the cleanest possible MF to use on interior glass, anything else and you're just making the problem worse.
Without ac vent mode and crack the window tops a bit
With a/c you want recycle mode because it runs the air inside the car thru to dry the air , i grew up in wet snow conditions and over 35 years thats how you cleared windows the fastest , if you open the outside air it brings in damp air and takes longer to clear since the humidity is still high , go buy a 2 dollar humidity gauge and watch it both ways
Yes clean windows free of the dash cleaner haze and smokers yuk or even dust , will make the windows clear faster , do not put air on the floor when your trying to clear them wait till your good and dry or it will fog up big time with wet floormats
tint seems to clear faster then glass as well but i would say its the temp difference it acts as insulation a tad
Edited by Carbon 34
Anyone wanting to clean glass, use Newspaper instead on other things,
No streaks ever and 100% cheaper :)
Dont do it !!! In the navy bootcamp we used newspaper and vineger the glass was scratched bad from it !!! It does work but not safe over time
The glass looked like a bad detail job buffer fine scratches
Edited by Carbon 34
go buy a roll of home brand paper towel from Coles or woollies. don't be a tight ass on the paper towel when cleaning, i use about 10 sheets per window or per half the front window.
newspaper has never worked for me and is best to clean the BBQ with :)
Vinegar(white) works great on glass ( not tint) it takes off water spots and not harmful to most things , pop into spray bottle and mist it on the smell actually can kill other odors , you can use it on a zillion things if you find the guidebook for it online
Home brand towels are even worse , like friggan sandpaper
Use a proper soft microfiber towel ( only use it on glass and do not wash in fabric softener ) if you do it streaks like hell on paint or glass
It works a treat on grils , sprinkle on baking soda after misting on and watch the foaming drop off the grease , actually in the navy lime cordial is used on grease go figure ?
Edited by Carbon 34
I'm not even in the car when theres condensation!
By the way guys this is the outside. I think many of you guys are thinking it's fogging up on the inside. Condensation is different from fog. For the inside, there's Rain X Anti-Fog :)
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
