R34 GTT Four door Stripped parts
(SHELL IS GONE)
R34gtt Front seats -$200 with rails
R34 GTR fuel pump with cradle -$150
R34 dash -$100
clutster -$100
climate control -$125
center console -$100
glovebox-$25
Air bag steering wheel-$100
auto shifter-$5
a/c centre vents -$70
a/c side vents -$30 each
door trims -$50 each
window switches $20 each
hood lining -$50
sun visors -$15 each
(heaps of other plastics just inquire if you want something)
R34GTT RB25det NEO 137,000kms motor complete minus turbo -$1500
R34GTT computer loom complete-$150
R34 Highflow turbo -$800
R34 auto triptronic gearbox flex plate converter etc-$300
cross member-$100
steering rack-$150
castor rods with ajustible bushes $100
GTT brakes calipers front and rear slotted rotors front (near new) stock rear $900
Front hubs and knuckes $150 each
Rear hubs -$100 each
lower control arms $80 each
rear cradle with hicas-$100
rear camber arms $25 each
rear toe arms $25 each
Front upper arms $25 each
Reinhard jap made 3" ENR34 SS exhaust with cannon good condition sounds great-$400
R33 GTR radiator with twin thermo fans-$100
AU falcon twin thermo fan setup-$50
R34GTT doors complete-$100 each
Front bar (cut for intercooler) $150
R34GTT/R33 GTR Ohlins Coilovers-$900
Blitz SUS stainless POD filter ok condition-$50 with AFM adapter
R34 tripple guages with autometer smoked volts oil pressure water temp $150
Clear side inticators-$25
BM44 brake master cyclinder with brake booster-$200
18x8.5 18x9.5 Starcorp impuls with tyres-$800
17x9 +22 x4 Sparco light weight wheels-$800
PM for any more info etc everything located in Newcastle
0422646961
Chasing the stereo surround that goes around the din and below the AC controls
AND
The lower dash section between the gear surround and the top of the dash where the gauge cluster is
Must be good condition and need both sent to Adelaide 5067 please
AND
Both items $100 shipped
Hey I'm after the plastic bit under the ash tray and the rear? Thanks
Price listed centre console plastic $100
Hi mate,
What condition are the coilovers in? And just confirming they fit 1999 GTT? Don't happen to know the spring rates off the top of your head do you?
Cheers,
Shazza
Edited by XS80ST
hey shazza... thry were great when thry were in my car handled nicely all dampeners worked fine... not sure on spring rates i belive the part no was nis 10m ? i think i can confirm later if u want ? and yes came from a 98 gtt so thry will fit
Hey, I was just wondering if you are selling the interior door pannels? Also is the steering wheel still in good condition or has the leather started to go on it?
aircon condenser?
yes $100
door cards price is listed $50 each wheel is in pretty good nick
Can you get a picture of the steering wheel without that cover please?
Cheers
posting a pic now
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
