  • 2 months later...
  • Replies 44
hmm, well they both cost around the $1000 mark I suppose. I did coilovers first as I hated the 4x4 spec plus wanted that extra reponse with handling. I would say the extra power with nistune would be more usable with coils installed, at least around corners. Car definitely feels safer and more responsive with them.
Probably get my nistune done in the new year so will let you know how I go.
Hey mate i have the same dilema as you. I want to order in a nistune from the website. Car is r34gtt
56,000 on the clock
Mods. Fmic, coilovers, catback, pod filter, bov. i have a hks old school evc but that stoped working for some reason.
Now my question. How much did you pay for the nistune?
Did you fit it yourself?
I got quoted $1500 supplied fitted + tuned.. Is this a good deal?
Sorry if im crashing your thread.
Cheers, anthony
I managed to nab a board for $200. Club sponsor tuner quoted me around $80 to fit and a couple hours tuning time from memory which is around $150/hr. So comes in well under 1k
I would say you could easily find a better deal that what you have been offered, espesh being in Sydney. Check out the sponsor threads or ask some locals.
Cheers boys, Yea i got that quote from croydon i found them in nistune website qhen i searched for local tuner under there.
How do i get in contact with with this people?
Sorry mates im just a newbie in this forums. I just shop here a lot lol
MRC are in Castle Hill and have the imaging gear for Nistune. Mark was very helpful a few weeks ago when he re-imaged my board prior to a tidy up tune with Jez.
Unigroup are in Girrawheen and I believe Yavuz is also working out of Windsor as well.
DVS-JEZ is a member and is a champion bloke and is very helpful, careful and thoughtful with his tuning.
56,000 on the clock
Cheers, anthony
Check on ebay... There's a guy who does it for 750-850 supplied, installed and first tune. Thats where I am going
  • 6 years later...
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
