You should have access to the open beta as off now if you pre-purchased it.
Played it for a bit, feels like CSS with uprated graphics. You need to play with the settings though, stuff like mouse acceleration are on by default.
Other than that it plays really well.
i bought this last week. was surprised to see it was only $15 on steam. not bad for gameplay. i think the skins need to be updated (t's and ct's are hard to tell apart) and the buy menu is definitely console oriented now. bit annoying that they changed the shortcut keys for a couple of things. still good fun though. havent played cs for the last year or 2 lol
As a CS player since the very first version in 1999 until now, I honestly say, congrats for attempting to botox some life into CS but I must say, it's just simply fcuking gay.
I would not recommend it to anyone. Overall the game seems and feels too animated. Not to mention silencers are out, the gayest tip of the dick is the new decoy grenade (does this even exist? LOL). You throw it like any grenade and it explodes into sound of gun fire for about 4 seconds.
CS Mod - Cool mod
CS 1.0 Stand alone - Good
CS 1.5 - Better
CS 1.6 - Great!
CS:CZ - Best CS out (in my opinion anyway, a good balance of graphics, not too stupidly animated but better than 1.6)
CS:S - Great-ish, better graphics but guns look like Go-Lo toys. This is the tip of the iceberg
CS:GO - A ride in a theme park. Tip of a gay's dick.
When I figured it was released, being a CS player for all these years, I impulsed into buying it, played the first minute in the training mode, was shit. Started a bot game thought it would be better LOL. After a fruitful win in the first round, the second round was an uninstall and delete.
CS Mod - Cool mod
CS 1.5 - Better
CS 1.6 - Great!
Id be the same I think, not gonna even bother. I starting playing in 1.0, soo long ago now lol.. 1.3 was where it was at :D bunnyhopping all over the place haha. 1.6 was great till they removed the quick scope/nade trick with the awp! :( gave up after 1.6, sauce&CZ were terd!
Miss the days of online, ETG/gamesurge & all the clans some good guys in the community
You are half correct in saying that but if you played CS:S when that first came out, that wasn't very good either. However now it is "perfected" and is a great game.
Give CS:GO a year to sort out all the bugs that come along, and i am sure it can be a great game as well.
However, i have the same opinion like you, it does not have the same feel that 1.6 or CS:S has, feels redone, sluggish, slow. A let down in my eyes.
BTW CZ was the worst imo.
yeah thats my only pain with the game... I have NFI which team I am meant to be shooting at haha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
