  • Replies 136
I'll likely be on tonight. Depends on how the wife and the very little lady are when I get home :)
If we get another group running, it would be good to try and coordinate a bit better. A couple times last night we made good ground by knowing where everyone was going and it's nice to have complimentary Squad buffs. Ash and I nearly got around behind them at one stage, thanks to having the ability to communicate. It would have become a slaughterfest if we'd made it past the first three guys.
Yeah if we only got around, so so close. Just needed and Assault with us and it would've been massacre.
I ended up playing Metro again later on, and got around the back in a similar fashion and minced 7 people down in a big spray push. Was hilarious :D
You dudes played close quarters/gun game?
I was skeptical as I always hated all the close quarters rocketry/grenadey shenanigans, but I have to say - it's awesome! Probably because there are no rockets and grenades must be earned right at the end.
Takes uber concentration though, can't really handle more than 2 games in a row!
Ive played a few gun games, but I always get frustrated with that retarded automatic shotty and get stuck for ages. I swear that gun is bugged as I can't kill anyone with it. But give me any of the other shotties and I can go on a rampage easily.
But I agree, the close quarters modes are heaps of fun, I play alot of conquest domination. Because of the random spawns and lack of long corridors like in metro, you avoid rocket/nade spamming
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
