Osiris is good for whatever you can get a AFM to read. Has been used on cars with over 1000hp (USA)
With an AFM upgrade it will do everything that the HKS kit will do on a std motor. Without boost control, you dont even need to upgrade the stock AFM.
Also HKS FCon is available.
  • Replies 80
got most shit sorted plugs etc.
thinking about using royal purple oil and filter. its not cheap but is it worth it?
also turbo timer HKS or Apexi?
any recoms on electronic boost controller?
what about deleting the cat?
cheers :no:
Go Motul 300v or NEO. Both are better than RP.
No turbo timer - not required. Just drive comfortably for the last block or two before you get to your destination
EBC - HKS EVC, Blitz IBC or Greddy Profec B.
Why delete the cat? Just get a high flowing cat. If it is the HKS turbo kit, leave the cat as is.
Definitely aim to keep some kind of catalytic converter in the vehicle to at least keep it street legal. There's no point in having a nice performance car if it gets taken off the road for failing emissions tests in random inspections. It's way more hassle than its worth.
cheers :no:
Cheers, then shakes head no? *confused*
anyway- what injectors are you using? Did you get a real ECU solution?
Royal Purple is fine, its in my car atm, but as iamhe said - there are better oils again. Buy filters from nissan
As has been said- no need for turbo timer, your expert friend should know that. turbo is oil and water cooled and as long as you dont flog it and turn it off right away will be fine.
Use a simple manual boost controller, unless you like spending 4-600 on something fancy. It'll do the job, but you'll just lose 1.5psi in the top range. nothing bad.
Kit comes with a high flow HKS cat unless you didn't get it. Suggest you use it.
if u get the utec hen it comes with optional boost controller and u cna program 5 different maps and change with press of a button..
As for oil, go on g35 driver and search, for FI most use Mobil 1 or Shell Rotella Syn T
RP is expensive and doesnt like our engines...
If you have a mongoose alarm most have turbo timer func built in you can program. If not then dont worry about it, just drive it slow before you get home and let it cool down..
cheers for the help guys,i know i dont need the t/t but was trying to be cautious.
undecided about ecu got a couple of weeks to sort it out before install
surprised to hear that about royal purple my mates swear by it but then again they drive commodores lol
also im missing one of the centre caps from my LMGT4 rims they are two piece with the outer one a threaded plastic cap you can see them in the picture. Any idea where i can buy one or is it easier just to buy a new set in a different style? cheers
exhaust manifolds and front end off, new manifolds and turbo on!
the bloody heat shields were the biggest pain took an hour to get each one off!!!
only a bees dick of room for the turbo didnt think it would fit for a mo!
intercooler next :yes:
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
