pics in my profile garage if u need proof 294.7rwhp until it leans out.
need bigger injectors cos im only running 6.5psi :yes:
look at mod pics
thanks to dean at WA automotive specialists in perth, and Jamie for his MEGASQUIRT ecu which did what a haltech couldnt
goes fkn hard :cheers:
  • Replies 80
the ABS light is coming up on the dash and we cant figure out why. anyone got any ideas? doing the dyno power run tomorrow so will post the sheet up after work to keep you number guys happy lol. no matter the figure its a different animal than it was :yes: might have to plumb that screamer back in though its f@#!$n noisy!
also did anyone have a funny little aerial on the drivers side dash in their v35? i thought it was something to do with the toll roads but it was conected to lots of little modules and boxes one which contained a brand new brown nissan key that didnt fit my car????? does this have something to do with the abs maybe? beats me.
Just get a scanner and read the diagnostic code. That will lead you in the right direction. When you can achieve full boost very early, I'm not sure a screamer was the right choice. Mines plumbed.
the kit came with the screamer but ill weld it up tomorrow got plenty of tube and flanges handy anyway. not showing any codes thats why im confused. any ideas about that little antenna thingy? it was wired into a lot of different things
Think it might be to do with the security and GPS system in the pop up dash. Just leave it alone. Nothing to do with abs. Abs computer is different to motor ecu, so codes won't come up with the manual process I think. Needs compatible scanner. Otherwise don't worry about it.
Remember you have stock injectors before you go into heroic power attempts...make sure your tuner is monitoring knock.
let the missus drive last night cos i had a few. not a good idea lol whats the best cleaner to use on leather seats???
shes driven my mates boss270 and thought that was a fast car,until last nite never again methinks
interesting to read.that works out to 220kw @ wheels by my calculations.
for comparison, my HKS GTsupercharge'd V35 makes 234kw @ wheels at 7psi max boost.
so, basically similar results whether you go turbo or supercharged in terms of peak power. i wonder how the power deliveries would compare?
what injectors are you running currently?
i suspect your setup will be able to produce more peak power once you sort out the tuning/injectors and whatnot. i guess depends how much boost you want to push taking into account reliability..
its actually 237rwkw but whos counting.
stock injectors at the moment so im not gonna up the boost until i get bigger ones.
im making roughly 18hp for every pound of boost i add but ill sit on it for a while.
the kit was making 270kw@ wheels @9psi on the z it came off but that was a 6m/t
each to his own i guess
i like the fact i can change boost whenever i want and that noone over here has a turbo v (that i know of) while there are a few s/c on Vs and Zs
plus that turbo does whistle nicely
hi all
car is runnin sweet apart from a couple of little issues
1 : cel,slip,and vdc lights wont turn off
i think its because the megasquirt runs the injectors now so gonna wire in some resistors to factory ecu to trick it. tried manual reset but that works until i turn car off again then lights come back once i restart. annoying!
2 : installed an Apexi turbo timer cos its a lazy mans tool so it suits me fine,but,it only seems to work if i drive a short distance. any more than 5kms it wont turn on. is there i setting i can adjust or just swap it for another? also annoying!
1000cc injectors for xmas then a run a 8psi
cheers
1: go and read the error codes and hope to hell they are not for Knock. That will tell you where to go- could be for too rich/ too lean, or misfire, or CAS AFM etc etc.
2: Useless Turbo timer is useless. Turbo is water cooled. As long as you not coming off a racetrack and turning it straight off, there is no point. Easiest thing to go - just don't flog it for the last 5 mins of your journey. Rip it out and sell it to some other bloke.
i also have CEL permanently on - dynoe'd it to make sure no knock/leaning etc when I purchased the car and all good. i cant remember the error code, but i beleive it is to do with the oxygen sensors in the cats - they are very sensitive and as soon as one reads a value outside the normal range (which happens all the time running supercharger with aftermarket ecu,larger injectors, etc) it activates the CEL.
i have also been told this by an official HKS approved worshops in australia who have seen this commonly on super- and turbo-charged VQ's.
not sure what the deal with your slip and vdc lights though..
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
