Swapped my CA18 intake cam for an exhaust cam and fitted adjustable gears at the same time.
Took pics of the timing marks and was pretty sure the car was at TDC on the comp stroke, confirmed by the piston location (removed spark plug) and cam lobe and valve location when I removed the rockers, so I know it wasn't TDC on the exhaust stroke.
Put it all back together and now it will crank but won't fire, managed to get it to fire and idle roughly with a bit of throttle but as it was running like crap I shut it down.
I also marked the CAS ad tried advancing and retarding it, no dice.
I'd have thought it'd still start if a cam or both cams were 1 or even 2 teeth off.
Thoughts?
Edited by ActionDan
OK to try and time it while cranking?
I'd resolved to pull all the timing gear off again and start from scratch. Everything was fine until I did this swap, and the CAS is back where it was so I'd say it's off a few teeth in a few spots.
I AM the tuner :D If the cover is off, the CAS can't be mounted without a new bracket which I don't have so it has to stay on.
How far would it have to be out to not start, the marks are pretty much dead on according to my before and after pics. If it was that far out surely it would've fouled when I turned it by hand first.
Ok good news. Got the missus to give me a hand and got the gears in place and the belt on (intake was about 3 teeth too far advanced, exhaust was about the same but retarded so no compression... Counted the teeth between the marks and it's spot on.
Will re-assemble tomorrow night and see if it starts.
All good, started it tonight, idled fine. No timing light here but if nothing else the idle revs are the same.
I have other issues now but they go beyond the scope of this thread and I'll continue on that path in my build thread.
At least we know it wouldn't start because the timing was out too far so I'm a goose.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
