  • Replies 55
I prefer 255/35 on a 9.5.
I'm old so stretch doesn't appeal to me but hey if thats the new craze I'm fine with that too but not on my car.
I'm not sure of the effect on the tyre wall, if any
Yeah thats a good size (what I have in RS-R format though so more a 265).
If you go with too much stretch, you end up wearing out your sidewalls pretty quickly.
Cheers guys.
Ain't being a tight arse otherwise I would be driving on cheap shit tyres. I like it, it's the look I was going for and it has a more direct road feel. This is my family daily so I don't need 265/35 RS-R's or equivalent. Also I don't have room to run a wider tyre unless i raise it up due to the poor coilover clearance in the rear because of the cargo area.
Alligators gon' alligate
Wearing them out? What's your reasoning behind this statement?
Talking extreme hellaflush spec... :) When running -5deg camber + say a 225 on a 9.5" rim, you actually wear out the sidewall really quickly as you're rolling on it to an extent. Anyway, It's all g, have it how you want, I prefer fat tyres :)
I thought you ment under normal fitment. There's clips of VIP spec cars with almost 10 deg camber with sparks flying off the rims cos there not enough tread
I know for a fact the Michelin PS3's 235/40 R18 will fit perfectly on a 9.5 inch rim, but that is the only 235 that would fit. It changes from brand to brand and even from style to style inside brands.
And GTRKat is right when it comes to Costco tyres, they are cheap Bridgestones/Michelins in small, and common performance sizes but not in the bigger stuff.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
