Hi there everyone
I Have just brought 96 rs4 stag with 140000km on the clock and i have had it for about a week now and today the engine has just started to make a ticking/clicking noise. The fequency of the noise gets faster as the revs increase and i have seemed to located the noise to back of the motor toward the firewall by putting a screw driver against the motor and putting my ear against it. I have a 12 month warrenty on the car so it will be getting fixed anyway but just wanted to know if it could be something serious or anyone had any ideas on what it could be. I have a video of it for you guys to listen to also..
Thanks
https://www.sau.com.au/forums/topic/407175-rb25det-tickingclicking-noise/
Is that the diesel RS4? :P
Sounds like the lifters are shagged, apparently the hydraulic lifters can be cleaned or they will just replace them. Take it back and let the mechanic listen to it.
Haha sure does sound like a diesel just glad it's not smoking like one.
But thanks does sound like it could be the lifters after doing a bit more research on it
Cheers
Just for one other thing to check, is there any chance the plugs are fouled?
Yeah it's possible. Although the guy I got it off said he had had it serviced when he got it but he also said it had been sitting on the lot not doing much for a few months. So yeah maybe some of the plugs could be corroded and stuffed
Thanks
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
