i would be suprised if it didnt cope, me and my tuner are amazed how good this stuff is, im running no more than 20knock on the power fc... its sweet as
but you'd be silly not to do a GTR intercooler atleast... my intercooler was only $400 and $300 to fit up so dont try and be cheap with it or you'll end up getting a crap result..
wow.. just saw you got 3L twin... man that has massive potential with some decent turbo's and E85... happy times ahead if that is done right.. :thumbsup: a 300zx was my second choice of car if i didnt get the r33...
Edited by SliverS2
well, judge me all you like, im just saying 20psi 320kw and very very little knock with 6degrees of extra timing ...
im confident that this fuel would do ok with only 14psi and conservative timing and still make some decent numbers, but i did say put an intercooler on it didnt i??
ill say again.. its very good fuel and you can achieve above and beyond 98 ,, my tuner will vouch for that too
less than 5knock just means your soft cock lol :P
I'm still pondering whether i should go the WMI route or the E70 route. A water/meth kit is cheaper than new injectors and a pump. Not 100% sold either way due to my setup not being that "hard core" but needing one or the other to put any useable boost in. The Base Map i'm using for it has 15 degree's removed from peak torque and 5 degrees removed up top and was used in a similar setup on only 7psi.
dunno what you guys are on about really.. do you actually run flex fuel or are you guessing about it, cause i watched my car on the dyno and being tuned by Gavin Woods whom i fully have confidence and respect for... does an awesome job and absolutely safe tunes... when you go get a job as a tuner and succeed like he has then come back and preach your knowledge with results like he has and then ill agree with you..MAYBE
just trying to help with some constructive comments.. GL with it the 300ZX should love it.. ive drove a 300ZX non turbo and turbo and even the non turbo had balls so will be interesting whatever you do
Edited by SliverS2
lol... interesting way to gauge the effectiveness of a fuel???
Well considering the RON (research octane number) value is measured via knock feedback on a variable compression engine I would suggest that you would be able to make some fairly valuable results from monitoring knock levels with 98 vs e85.
To the original poster if you are knock limited than you obviously need higher octane fuel to achieve a better result/higher knock resistance. An intercooled will help cool the charge making it less prone to det but will not aid in octane. Wmi will do both these things. If it were my car I would make the intercooled fit and run e70 - this is obviously the best solution..
Ethanol is just like methanol. It would work well without an intercooler. Obviously E70 isn't as good as methanol so the cooling effect isn't going to be as good.
I'd still run one, not worth the disadvantage
From what I've seen e85 vs methanol - it is nowhere as good at keeping temps down. We had no cooling issues with a methanol injected 350chev - swap to e85 bam, not enough coolant capacity/radiator and we had heating issues. This was a drag car with small radiator.
You only need to look at the extra volume of fuel required compared to e85 to see where the cooling comes from.
Thier point was the fact your tune does not knock has little to do with the fuel and more about the state of the tune. And basically overall your intercooled results are irrelevant for this thread. So more-to the point, no-one is sure what you are on about!
To the OP - VL's were running what, 5psi through a small T3 and were ok and you could get upto around 8-10psi IIRC. This is back in the 80s :)
That said - it's not just about the amount of boost.
14psi through a t04Z or 14psi through a stock GTS-t turbo? Two very different ends of the field and resulting heat. saying "14psi" isn't relevant in it's current context really without knowing the entire setup. Your setup will also be quite sensitive for sustained use as well as heat increases.
You'd need to get a few sensors going IMO and monitor it carefully and work your way up. It might be fine now in cooler months, and all of a sudden one warm day, 1hr drive and all of a sudden you've got stones under the bonnet :thumbsup:
    • Crazy how good the aero bar looks compared to the stock one
    • Yes, but you will need to rewire all the things that are different. CAS, coils, etc. Yes, but there is no IAT. What? You can use anything you like. It just has to be hooked up so that it will work.     Or are you wanting to just plug and play without having to do any thinking/work?
    • It's been a little over a decade since I bought the S15. As I did on my socials, I'll share some of my favorite pictures from over the years further below. If you haven't realised, pretty much all the pictures in my posts are ones I've taken.  In terms of updates, I don't have pictures, but I acquired a near-perfect pair of fog lights from a friend of mine, so those got swapped in for the pair I already had. As for the JZX110, I just got it back from being fixed. A few weeks back, I was on the highway when I suddenly drove over something with very little time to react. It was probably the size of a soccer ball, but it went under the car and banged into the underside pretty loudly. I pulled over and realized the fluid leaking was fuel, and of course, it was right near my exhaust. This required replacing the fuel tank. If you happen to be in the same predicament, thankfully this car shares a fuel tank with the JZS171, IS200, and IS300, so it wasn't too painful to replace. Enjoy some pictures as mentioned above, including the carnage from the fuel tank and a bonus picture I came across which shows how ridiculously shiny the Bugels are on the 110. So many more pictures I could share of the S15 but this will do for today, enjoy.
    • Welcome.  Was the mistake the car, or joining us? 😏
    • Yeap, was me and the daughter getting coffee before heading to the new joint to measure up the fridge space and taking some pics that the solar installer wanted of the switch board
